Found 440 Engine, possibly 69 Charger RT or 500? #2700494
09/24/19 03:38 PM
09/24/19 03:38 PM
Renton Wa
topfueldart Offline OP
Renton Wa
I have an engine which has long kept me wondering, maybe someone has the car somewhere. Most likely was in the Northwest. First two digits are missing from the stamping on the pan rail.
-- 29L9B249388 or -- 29L9R249388
XX29? XS29? Does the 29 "2 Door Sports Hardtop" apply to anything other than a Charger?
From my little research seems like this is most likely from a 69 Charger, can anyone confirm or expand on this based on the portion of the VIN I have?
Thanks!
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: Found 440 Engine, possibly 69 Charger RT or 500? [Re: topfueldart] #2700508
09/24/19 04:18 PM
09/24/19 04:18 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The only two plants for '69 Chargers were B - Hamtramk & G - St. Louis, so no R, but a poorly stamped B is very possible.
The other possible '29' VIN from Hamtramck would be a BH29, but in that case with a 440 the engine code would be an M.
Re: Found 440 Engine, possibly 69 Charger RT or 500? [Re: topfueldart] #2704849
10/08/19 12:36 PM
10/08/19 12:36 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
it would've been a '69 Charger R/T - full VIN XS29L9B249388
Re: Found 440 Engine, possibly 69 Charger RT or 500? [Re: 6bblgt] #2721063
12/03/19 02:41 AM
12/03/19 02:41 AM
RI Deep in the rust belt
chargervert Offline
chargervert  Offline
My former 500 was XX29L9B239388.
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
