Valve cover recommendations #2699206
09/20/19 12:07 PM
09/20/19 12:07 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Hello all..
I'm looking for a recommendation for a B1-O sheet metal valve cover... I'm not a fan of the cast B1 valve covers and currently am using the Williams Bros sheet metal... However the flange is so wide, I can not install using studs... Seems the T-D 1.7 rockers will hit the flange... So I am currently using wing nuts to hold the valve cover on..
Does anyone have any recommendations for another manufacturer that would accept studs?
Thanks in advance
Re: Valve cover recommendations [Re: Jeepmon] #2699209
09/20/19 12:15 PM
09/20/19 12:15 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Take a look at the 440source ones. I happen to have a set and Tom Hemphill told me they work great
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Valve cover recommendations [Re: pittsburghracer] #2699211
09/20/19 12:19 PM
09/20/19 12:19 PM
PA.
"Little"John
"Little"John
PA.
Found a picture but on this site it will probably be sideways
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Valve cover recommendations [Re: Jeepmon] #2699232
09/20/19 01:26 PM
09/20/19 01:26 PM
Cab_Burge Online work
Cab_Burge  Online Work
I've bought and used several different brands of polish aluminum sheet metal valve covers, one set needed trimming of the flange on the inside ends in the corners to get them to slide on and off with short mounting studs with a set of Harland Sharp 1.6 ratio single shaft rocker kit shruggy scope
Re: Valve cover recommendations [Re: Cab_Burge] #2699487
09/21/19 11:05 AM
09/21/19 11:05 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I would check with Doug Lee:
http://propan.net/
Doug Lee Engineuity
Address: 9201 S. 650 Rd., Miami, Oklahoma 74354
Phone: 918-542-4686
Email: dlee@propan.net
Facebook: https://www.facebook.com/DougLeeEngineuity
Re: Valve cover recommendations [Re: pittsburghracer] #2699551
09/21/19 03:42 PM
09/21/19 03:42 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Those look almost like the Williams Bros I have now... Any chance we can get a pic of the inside and flanges?
Re: Valve cover recommendations [Re: Cab_Burge] #2699553
09/21/19 03:44 PM
09/21/19 03:44 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Yeah Cab... thats the problems I have... we've trimmed so much of the inside flange, it makes sealing the gasket difficult... plus, the B1 uses the 1.7 rockers...
I guess if I cant find anything decent, I will go back to the cast B1 covers
Re: Valve cover recommendations [Re: 340Cuda] #2699554
09/21/19 03:45 PM
09/21/19 03:45 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
http://propan.net/
Doug Lee Engineuity
Phone: 918-542-4686
Thank you... I will make a call to them next week
Re: Valve cover recommendations [Re: Jeepmon] #2699672
09/21/19 10:52 PM
09/21/19 10:52 PM
I ended up having to find a set of the early original B1 valve covers to make the B1 V.C. gaskets work shruggy
Re: Valve cover recommendations [Re: Cab_Burge] #2699864
09/22/19 01:32 PM
09/22/19 01:32 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Thats another issue... without a front mount distributor, its difficult to fit the passenger side valve cover
Re: Valve cover recommendations [Re: Jeepmon] #2699873
09/22/19 02:12 PM
09/22/19 02:12 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I also hate the B1 cast covers.
I am pretty sure that I will be able to make my M/T cast aluminum covers work with my new B1 MC heads, but won't know for sure for a few more months. Its been a lot of work to make them fit.
Re: Valve cover recommendations [Re: markz528] #2699875
09/22/19 02:16 PM
09/22/19 02:16 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
But if you want a sheetmetal set that fits, supposedly these are the way to go for B1 MC (and standard B1) heads but not cheap at $600.
http://www.billetfab.com/
Re: Valve cover recommendations [Re: markz528] #2699959
09/22/19 09:04 PM
09/22/19 09:04 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
I like them... Thanks
Re: Valve cover recommendations [Re: Jeepmon] #2700233
09/23/19 07:31 PM
09/23/19 07:31 PM
PA.
"Little"John
"Little"John
PA.
Sorry it took so long but here are some pictures of the 440source valve covers
87E43C97-7DAC-4D09-A7C7-A49D43D8F4DC.jpeg01764EC6-F105-47E6-8A5E-9D60B3C156D4.jpeg5D388F66-4188-4815-A916-19F16CAE487B.jpeg
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Valve cover recommendations [Re: pittsburghracer] #2700309
09/24/19 12:08 AM
09/24/19 12:08 AM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
I have used a few dif. sets of jeff Johnson covers, all with good results, as you know I am currently running a set of billet covers with a one piece o ring to seal instead of a gasket,if you go with the jeff Johnson covers, he may be able to install them in your covers, I know there is one of our mopar brothers in Australia I think who is/was making billet covers for B1 heads,that would be the route I would go if you can find him....
Re: Valve cover recommendations [Re: boatracer572] #2700311
09/24/19 12:13 AM
09/24/19 12:13 AM
San Jose Ca.
San Jose Ca.
Don, LA360...…. is the guy who I was talking about who has billet B1 covers
Re: Valve cover recommendations [Re: boatracer572] #2700347
09/24/19 07:44 AM
09/24/19 07:44 AM
St.Pete,Florida
lancer493 Offline
lancer493  Offline
St.Pete,Florida
Pittsburgracer's pictures of the 440source valve covers seem to show that there is a lot of room, internally, to accomodate a variety of rocker arm/valve train arrangements, and cost effective as well. Cover sidewalls seem to be set at the outer portion of the gasket rail, freeing up a lot of room for rockers. They appear to be just what I'm looking for. Thanks for posting the pics. Bill
Re: Valve cover recommendations [Re: lancer493] #2700348
09/24/19 07:49 AM
09/24/19 07:49 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
I have the 440 source sheetmetal ones in the pics. They are great. Fit over T and D rockers, and they don't leak. As expected slight grinding in the distributor area but that's it.
....BAD A$$ STREET CAR.....
Re: Valve cover recommendations [Re: lancer493] #2700411
09/24/19 11:02 AM
09/24/19 11:02 AM
PA.
"Little"John
"Little"John
PA.
Glad I could help. When I dropped my 572 in my Duster I had to use the valve covers that came with the B1 heads because of master cylinder clearance. I now have everything to move the master cylinder over and will do so after race season is over.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Valve cover recommendations [Re: pittsburghracer] #2700443
09/24/19 12:22 PM
09/24/19 12:22 PM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
wow. what headers are those?
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
