78 Dodge truck ignition module problem
#2697589
09/14/19 07:58 PM
09/14/19 07:58 PM
Posts: 1,230 Pittsburgh, PA
wayfarer1
Pittsburgh, PA
Found an issue with my dad's 78 Lil red express today. What could have caused it to melt?
Current Project: 72 Roadrunner 340/727/Petty Blue/White Roof Strobe Stripe/Black Bucket Interior
71 Demon project
Re: 78 Dodge truck ignition module problem
[Re: topside]
#2697605
09/14/19 08:56 PM
09/14/19 08:56 PM
wayfarer1
Pittsburgh, PA
Thanks. We are going to get a new module and see what happens. The voltage regulator was replaced 8 years ago and it did the same thing. It was original to the truck as well.
71 Demon project
[Re: wayfarer1]
#2697701
09/15/19 10:08 AM
09/15/19 10:08 AM
RapidRobert
& confirm that it is grounded well
[Re: RapidRobert]
#2697719
09/15/19 11:09 AM
09/15/19 11:09 AM
wayfarer1
Pittsburgh, PA
Good point. We will check the ground as well. I can't seem to find the exact module for the truck. All I can find is the older style.
71 Demon project
[Re: wayfarer1]
#2697723
09/15/19 11:13 AM
09/15/19 11:13 AM
RapidRobert
Do you have a yard close by?
[Re: wayfarer1]
#2697725
09/15/19 11:17 AM
09/15/19 11:17 AM
wayfarer1
Pittsburgh, PA
Does anyone know where to get the newer style ignition module?
71 Demon project
[Re: Y3 70 BEE]
#2697784
09/15/19 03:10 PM
09/15/19 03:10 PM
Posts: 6,291 nowhere
Sniper
nowhere
That is not the ECU in your pic it is the EGR module. Good eye, for the record the ignition control module has a 5 pin connector that looks sort of like a pentastar. As for finding the EGR module, good luck. If you can find a PN on it you might be able to google that.
[Re: Sniper]
#2697803
09/15/19 04:13 PM
09/15/19 04:13 PM
wayfarer1
Pittsburgh, PA
What do you mean by EGR module? If it is something to do with emissions, then that is impossible as the truck is a 78 Lil Red Express and has absolutely no emissions on it. The module you showed is nowhere on his truck and never had been.
71 Demon project
[Re: wayfarer1]
#2697810
09/15/19 04:37 PM
09/15/19 04:37 PM
wayfarer1
Pittsburgh, PA
I found an EGR module on eBay and it is orange and the part number doesn't match our part.
71 Demon project
[Re: wayfarer1]
#2697815
09/15/19 05:01 PM
09/15/19 05:01 PM
wayfarer1
Pittsburgh, PA
Ok I am wrong. I found the ignition module under the ballast resistor and it is new. I admit when I am wrong, sorry for the confusion. I still don't know why this truck would have an EGR module on it.
71 Demon project
[Re: wayfarer1]
#2697829
09/15/19 06:36 PM
09/15/19 06:36 PM
Sniper
nowhere
there are multiple versions out there. Not all of them are orange, nor do they all have the same PN. Here's a partial listing of some.
[Re: Sniper]
#2697836
09/15/19 06:58 PM
09/15/19 06:58 PM
wayfarer1
Pittsburgh, PA
Thanks for the info. He has the part number we need but I am not paying $55.00 for a used, untested electrical part.
71 Demon project
