Re: time or rpm shifting
[Re: dragon]
#2697720
09/15/19 11:11 AM
09/15/19 11:11 AM
Posts: 2,673 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
You would think RPM is the only way but my last 3 cars were on time. I really couldn't tell much difference. If you spin at the hit the RPM might shift and leave you in 2nd gear where as the time shift won't.
2011 Drag Pak Challenger
[Re: dragon]
#2697721
09/15/19 11:11 AM
09/15/19 11:11 AM
Posts: 1,824 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
The car I got a while back is set up to shift on time why would you not shift on rpm I can change a setting and do either. Pro and cons Been down this road because every run is different and if you have to peddle the throttle it messes up if you go by rpm. I switched to air shifting manually now with a button .
[Re: Sammy]
#2697744
09/15/19 12:17 PM
09/15/19 12:17 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I prefer to shift on rpm.. main reason is IF you spin while in low gear(time) you have a better chance of hurting the overrunning clutch.. if I spin thats the first thing I do(shift)... I dont peddle the car.. basically if you spin you lost the race
[Re: MR_P_BODY]
#2697781
09/15/19 02:57 PM
09/15/19 02:57 PM
Posts: 11,645 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Everything on the track is determined by time. Every thing that happens is supposed to happen at the exact same time every pass. So why not the shift too? I'm talking bracket/.90 racing with a 2 speed.
In .90 racing, every thing after the stop comes off should be the same every pass. So...make sure the car dead hooks every time, have a powerplant with a flat torque curve and maybe even short shift it a bit, at the exact same time every pass. The big MPH .90 cars drop it into high gear just after going on the stop so it's a simple high gear charge when the stop comes off..
When I was .90 racing with a 3 speed, I would go to second a few hun after the hit, run the stop in second, and then shift to high by RPM. Sounds screwy but it worked pretty well. Like anything, you have to test, make laps and keep track of data.
If you spin? If you spin, you're done anyway unless the other guy screws up too. Make the car not spin is my advice.
[Re: dragon]
#2697840
09/15/19 07:15 PM
09/15/19 07:15 PM
Posts: 43,259 Bend,OR USA
Cab_Burge
NHRA use to have a rule that if your S/P, S/G or S/C car had a tach in it you couldn't have the box shift it off RPM Hence the use of time instead to shift it As already pointed out, both work well I would try both to see which one YOU like the best
