Re: new project 1966 Hemi Coronet 500
[Re: UCUDANT]
#2691855
08/27/19 09:29 AM
08/27/19 09:29 AM
Posts: 3,139 tennessee,usa
mattsmopars
tennessee,usa
Been a while since I have been able to do a lot on the 66. I have been collecting some parts and trying to get everything I need at least lined up. I do have my engine back, was into building it actually before the car purchase but with that it will go into this car. I did manage to get the new engine painted over the weekend. Still need to do the engine brackets and bellhousing, but at least some forward progress. Used the enamel paint from Roger Gibson, it’s a PPG shop line product. Matt
[Re: mattsmopars]
#2692533
08/29/19 09:02 AM
08/29/19 09:02 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
As for the mount leaving a paint mark on the K frame I think it was set onto the K frame while the rubber isolator was somewhat wet anyway. Matt Correct, Hemis were usually installed very shortly after being completed and painted, paint transfer to the K-member from the engine mounts was common. Bell housing was also installed on the engine when it was painted, usually a moderate amount of over spray covered the bell housing, complete coverage happened as well but was less common in my observations.
[Re: Va58]
#2713347
11/06/19 01:17 PM
11/06/19 01:17 PM
mattsmopars
tennessee,usa
How is the tail finish panel? sure wish someone would repop... no good, unfortunately I missed an NOS one on Facebook before I owned the car. Your correct most of these are not good. I'm also missing some of the trim around the tail panel on the trunk. Matt
[Re: NANKET]
#2713496
11/06/19 08:32 PM
11/06/19 08:32 PM
mattsmopars
tennessee,usa
That idler arm looks replaced. No grease fittings. Any Ideas? I personally don’t think it’s been replaced, unless the idler and pitman were replaced together. Both have painted black, and both stamped the same type of casting numbers on them. Maybe that will help to tell but I’m not sure. Matt
