Re: engine runs hot
[Re: moparjack44]
#2699776
09/22/19 10:43 AM
09/22/19 10:43 AM
Posts: 181 Ontario Canada
Bennoel 10
Ontario Canada
where do I start as I thought everything was covered. So here I go.... rebuilt 340 (stock),new rad with new clutch fan and shroud, new water pump, new heater core everything new as this was a rotisserie restoration. however the engine temperature gets very high. I have put 1000 miles on the car and it always runs very hot. over 200 degrees with a 160 thermostat. I noticed that the lower rad hose was cold when the temp. gauge read hot. the upper rad hose along with the heater hoses were hot. this lead me to believe that there was no circulation of coolant. pulled the rad, water pump, thermostat. everything checked out fine. the only thing that I found was the block wasn't cleaned out properly. quite a bit of sludge. found this out as a result of one of the freeze plugs rotted through. (engine shop closed down) Now I am wondering if this is my problem as I have lost confidence in the engine build. could the head gaskets be the problem?? maybe upside down causing blockage?? Not looking foreword to pulling the engine out. Any suggestions, similar problems??? Thankyou Moparts forum members.
Bennoel Do you know "for sure" it is running hot, or does the gauge says it's running hot. Is it steaming, is it pukeing? I had a "heating" problem on my 1st Gen 392. After much checking, re checking, doing and re-doing. I installed an after market temp gauge. ZAP,,,,, gauge problem, not heating ptoblem. used a mechanical gauge in the top of the rad and if I remember correctly it was over 200 degrees also used a infrared temp gauge now I'm worried that the head gaskets are installed wrong
Re: engine runs hot
[Re: Bennoel 10]
#2699792
09/22/19 11:11 AM
09/22/19 11:11 AM
Posts: 19,485 north of coder
moparx
as was said previously, some head gaskets purposely block coolant holes, so i would try it on the road first. however, i'm still wondering about the "rebuild" quality. you may eventually have to pull the engine and check everything, just to be sure of it's integrity.
Re: engine runs hot
[Re: moparx]
#2699859
09/22/19 12:57 PM
09/22/19 12:57 PM
Posts: 6 Pittsburgh
ratty
Pittsburgh
like said by another, 200 deg is not hot... and to throw my two bits in if anyone hasn't already said it... (and everyone has said great stuff)....
- coolant temps readings are only just that, coolant temp readings... not engine temp. One of the most common misconceptions is a thermostat rated for a smaller temp opening means your engine will run cooler... The coolant system is designed to transfer heat from the engine to the air, if you run a too cool thermostat, you're not letting the coolant absorb enough heat to transfer away from the engine. A hotter rated thermostat will absorb more of the engine heat, and though your coolant temp will be hotter, your engine will actually be cooler. So running a higher temp rated opening thermostat will keep your engine cooler, not hotter, and vice versa (that is, when all things else are running correctly).
- just because you have good visual flow in your radiator (cap off, engine just warmed up enough to open the thermostat), doesn't mean you're flowing coolant well. A rad can get clogged just enough that it'll look like it's fine, but, especially with a mechanical water pump, at lower engine rpm (and lower water pump rpm), coolant will flow fine, but at high engine and water pump rpm the coolant will start to back up, or rather, not keep up with the higher rpm... and will start to overheat and eventually puke. The engine isn't overheating, it's just the coolant overheating (though obviously once the coolant overheats and turns to vapor then the engine ends up overheating too, but only after the fact)
- always run a good mechanical water temp gauge in addition to your stock temp gauge, if you aren't already. You'll get a more accurate reading and you'll notice that even with the sensors side by side in the intake manifold (if that's where you're running them), they won't consistently agree with each other all the time... more data the better..
- what kind of fan are you using too? old school fixed fans are about as useful as no fan at all, clutched fans a lot better, shrouded over unshrouded any day, but you just can't even begin to compare to a good electric fan (but keep in mind that you'll need a higher amp alternator to run an electric fan)
- again, 200 degrees is not hot. Even if you had steam visually escaping from your rad's cap, that still doesn't mean you engine is overheating... Signs of your engine overheating are noticeable sluggishness, loss of power, and pinging. The only way to actually gauge if an engine is running too hot, is if you had EGT sensors at each exhaust port/header primary (or used a IFR gun, but that would only work with the hood open at a stop, unless you can convince a friend to hang onto the fender with the hood removed while you drove it around hard... hey, we all have a friend that would do that... ha)
But yeah, clogged anything is always bad, but you can have a good amount of sludge and old casting sand in the bottom of your block and it really won't affect much...
Hey buddy, is there a 440 in your Coronet 440? No, it's just a little 318.... (sound of crickets)...
Re: engine runs hot
[Re: Bennoel 10]
#2700194
09/23/19 05:31 PM
09/23/19 05:31 PM
RapidRobert
Next I think I will try a 180 stat and antifreeze. I would hold off on that tho winter is coming & temp does need to be above 180 & what Sniper said, there is an airflow problem (assuming the rad flows well). EDIT on second thought if the rd was partly plugged it would run hot a speed (more eng heat/not enough flow to cool)
Re: engine runs hot
[Re: Bennoel 10]
#2700525
09/24/19 05:07 PM
09/24/19 05:07 PM
Posts: 1,023 pa.
dan9
pa.
If it has not been mentioned check to see if there is a spring in the lower rad hose. If not it could be collapsing.
