car porpoising in high gear....... #2695429
09/08/19 12:10 PM
09/08/19 12:10 PM
St. Paul , Mn.
tubtar Offline OP
tubtar  Offline OP
St. Paul , Mn.
Finally got a chance to run the car hard.........3000 lb. '65 Dart. AlterKtion front end with QA 1 single adjustables , Cal Tracs in back with their 9 way adjustables.
I got it into third and it was still pulling hard but the car started to porpoise and it was getting more pronounced as it continued to accelerate.
It was pulling pretty good.
I lifted at about 3/4 track and rolled through at a 12.24 @ 110 , with a very soft launch.
I have the rear shocks at 6 and the fronts are at 4.
I really should scale the car and figure out the bias / balance , but have not done this yet.
I suspect that the condition is originating in the rear of the car , but would appreciate any ideas as far as what to look for or where to begin making changes to try and correct this.
What are the common causes of this ?
Thanks in advance for any help.
Re: car porpoising in high gear....... [Re: tubtar] #2695430
09/08/19 12:23 PM
09/08/19 12:23 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
What are the rear tires (bias or radial) and how much pressure are you running?
Re: car porpoising in high gear....... [Re: tubtar] #2695431
09/08/19 12:23 PM
09/08/19 12:23 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Double adjustable shocks are in your future.
I had the same problem, you need to tighten compression up.
Re: car porpoising in high gear....... [Re: Sammy] #2695440
09/08/19 12:36 PM
09/08/19 12:36 PM
St. Paul , Mn.
tubtar Offline OP
tubtar  Offline OP
St. Paul , Mn.
Mickey Pro ET radials.......I had 26 lbs in there , thinking since I wasn't going for a 60 ' time , it would do.
I discussed double adjustables with the wife on the way home...........warm her up to the idea that I might need to drop another chunk on the car. LOL
Re: car porpoising in high gear....... [Re: tubtar] #2695446
09/08/19 12:59 PM
09/08/19 12:59 PM
New York
polyspheric Offline
polyspheric  Offline
New York
I would video the car to see which end is acting up before spending any money.
Boffin Emeritus
Re: car porpoising in high gear....... [Re: tubtar] #2695455
09/08/19 01:21 PM
09/08/19 01:21 PM
central il.
second 70 Offline
second 70  Offline
central il.
You'd be surprised just what a couple of clicks tighter on the rear shocks will do. Had a friend with a Nova at the track just testing. Just took one click out of his rear shocks and his car when from being fine to looking like Flipper bouncing down the track put the 1 click bad in and no more porpoise.
Re: car porpoising in high gear....... [Re: second 70] #2695464
09/08/19 01:52 PM
09/08/19 01:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Tighten the rear extension
wave
Re: car porpoising in high gear....... [Re: MR_P_BODY] #2695499
09/08/19 03:57 PM
09/08/19 03:57 PM
St. Paul , Mn.
tubtar Offline OP
tubtar  Offline OP
St. Paul , Mn.
Next up is a go pro and some under car video , but I will definitely try tightening up the shocks first.
I'm not afraid to spend money on the car , but I'd much rather not if I don't have to.
I need a proper test day now.
Here's what it looked like on play day.
More than one hit would have been great , but I needed that one under my belt just to get the ball rolling and put my biggest concerns to rest.
Re: car porpoising in high gear....... [Re: tubtar] #2695550
09/08/19 07:55 PM
09/08/19 07:55 PM
gregsdart Offline
gregsdart  Offline
If all else fails it could be the front and rear spring rates are too close together. The spring rate numbers won't match but the force to move either end might be too close which can cause porpoising. A stiffer or softer spring on either end would be the easiest way to test for this.
Re: car porpoising in high gear....... [Re: gregsdart] #2695724
09/09/19 10:48 AM
09/09/19 10:48 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
You might give Calvert a call.
Re: car porpoising in high gear....... [Re: gregsdart] #2695887
09/09/19 05:51 PM
09/09/19 05:51 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
iagree
More time than not its the spring rates
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: car porpoising in high gear....... [Re: W.I.N. Racing] #2695888
09/09/19 05:53 PM
09/09/19 05:53 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
How smooth was the surface? You might take it to an actual track and see how it does before you jump on changing too much. Although I do think double adjustable shocks are a good investment no matter what.
68 Barracuda Formula S 340
Re: car porpoising in high gear....... [Re: Bad340fish] #2696093
09/10/19 11:12 AM
09/10/19 11:12 AM
St. Paul , Mn.
tubtar Offline OP
tubtar  Offline OP
St. Paul , Mn.
The surface was smooth as silk........asphalt runway , but looked recent.
It was a mile long , so I didn't even have to try the brakes , but it was smoother than some drag strips I have been on.
I am going to wait on calling Calvert..........plan A is to tighten up the rear shocks and give it a hit.
A friend who has had years of Cal Trac experience in both A & E bodies is going out with me next time , but I really appreciate the suggestions.
I figure there is more experience here on the board than in customer support , and if there is a consensus among posters , then I trust that information to a very high degree.
Spring rates will be the next deal if I can't sort it out with a couple clicks.
I like the idea of having a little more stored energy with a lighter spring in the front , and I don't know how I would go about changing the spring rate in the rear with the split mono leaf in there.
If I am still having problems , well...........our season is winding down up here.
But I will be ready for the opening bell next spring.
Re: car porpoising in high gear....... [Re: tubtar] #2696167
09/10/19 02:43 PM
09/10/19 02:43 PM
Cab_Burge Online work
Cab_Burge  Online Work
Have you check to see if your topping( or bottoming out) the shocks on both ends at max suspension travel? scope
I had one incident of porpoising on my old pump gas Duster, it started doing it on the starting line and got worst as it went down the track, I finally had to lift to get it to stop shock
Your car has plenty of front to rear rake so the faster it goes the more the wind should push down on the car, maybe not work
A close up vid from the front would help also scope
Re: car porpoising in high gear....... [Re: Cab_Burge] #2696215
09/10/19 04:40 PM
09/10/19 04:40 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
You can try to stiffen the shocks all the way in the rear,then you can determine who's shock to get!! I bought vikings all the way around.
Your results may vary...............
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: car porpoising in high gear....... [Re: Cab_Burge] #2696239
09/10/19 05:50 PM
09/10/19 05:50 PM
Byron, NY
Byron, NY
Adjustable Drag shocks are for launch control not ride control...fix the problem don't mask it at the expense of other functions twocents
'60 Willys CJ5
Re: car porpoising in high gear....... [Re: W.I.N. Racing] #2696260
09/10/19 06:38 PM
09/10/19 06:38 PM
St. Paul , Mn.
tubtar Offline OP
tubtar  Offline OP
St. Paul , Mn.
I have seen video of this happening with cars that reach the end of the travel with spring sliders.........I am not in that position I don't think.
I am also fairly certain that I am not bottoming the shocks on either end of the travel.
But I will get a Go Pro under there to be sure just what is happening.
I have looked the video over and it seems to be originating in the back of the car.
And there isn't any real sign of it till 1/2 track or so.
The wheelie bars are 3 " off the deck static , and the Cal Tracs are set to just touching , so I don't think there could be enough axle wind up to put them in contact with the ground.
But someone suggested that this might be a cause.
Video will give me a lot more information than seat of the pants , but I have never felt that before and the way it seemed to be escalating was not very comforting.
Re: car porpoising in high gear....... [Re: tubtar] #2696321
09/10/19 09:43 PM
09/10/19 09:43 PM
gregsdart Offline
gregsdart  Offline
Three inches is very little room for wheelie bars. I would start at about six to eight depending on bar length and how much the pinion angle will change on the hit.
