Re: My new Hemi Charger 500, 5th one built - Press Release
[Re: hemi68charger]
#2674528
07/05/19 05:44 PM
07/05/19 05:44 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Some cool parts that have shown up recently...
Today I got some Mopar goodies... A big shout-out to Wayne Perkins for giving me the opportunity to attain a NOS rear valance for the 500. Thank you !!! Trying to do the best with the funds I have. Would like to get original end caps at an affordable price..
But with the NOS valance, it will provide a good cornerstone for the corners.. See how I did that? icon_smile_big
Also, Julius came over and sold me a Tony DAgostino restored front sway bar.. Tony, that thing is nice and look forward installing it on a freshly painted car when that day happens in the future. Thank you Julius, saved me shipping costs to and fro...
The Emissions solenoids will be worked out as such.. I will replace the aging cover of the original 426 Hemi solenoid and mounting bracket I have on the Daytona and reuse it on the 500. I'll use the other solenoid on the Daytona and get a mounting bracket from Scott Smith..
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: hemi68charger]
#2693843
09/03/19 07:29 AM
09/03/19 07:29 AM
hemi68charger
Houston, Tx
Operation rotisserie 4 Charger 500.. Well, thanks to Bob for helping with the adaptor brackets and Dave Points for the rotisserie and help, for the old girl fitted today on the ole rotisserie for the future blasting and paint. It worked !!! Some shots of it and the special hemi-car body components. Now need to get the logistics of the blasting and paint shop.
[Re: gtx6970]
#2697279
09/13/19 06:34 PM
09/13/19 06:34 PM
hemi68charger
Houston, Tx
FYI, leave the plastic plugs in the ends of the rockers while it gets blasted. Getting media back out of there isa ROYAL pain . Trust me.
What media you going to use for blasting ?
Hey Bill, It is a crushed glass media with high pressure water... I would not have believe it if I didn't see it with my own eyes. He did a test for me on another fender I had since the undercoating is the same stuff.. Well, it went right through the undercoating without any problems then he told me to put my hand on the bare metal, it was cold.. Soooo, no worries on heat warping. This sure beats the heat gun and a putty knife in a hot garage over multiple days... Hopefully will get it to him on the 21st... Going straight to the body shop when they will shot the car with epoxy before dissection... Oh, thanks for the tip on the holes for the framerails... Yes, I guess it would be a PITA to get all that stuff out of it...
[Re: hemi68charger]
#2712506
11/03/19 06:39 PM
11/03/19 06:39 PM
hemi68charger
Houston, Tx
Accomplished another milestone this weekend; the blasting and delivering of the car to the body shop.. My last project Superbird took freaking 6 months or so.. This time, a weekend.. The car is pretty much what I expected.. Really solid in places and not so much in others. But, it can all be fixed.
[Re: hemi68charger]
#2712512
11/03/19 06:46 PM
11/03/19 06:46 PM
hemi68charger
Houston, Tx
Went and checked on the progress of the 500, took them my freshly restored hood hinges by RestoRick and go over some items that were discovered during the working (to be expected). Thanks to Robert and Bill Crabtree at AMD for the sheetmetal parts I've needed.. Took the ole Daytona to check it out. The passenger side isn't going to need that much, was just positioned for mocking. It'll just need the bottom surface below the reflector.
[Re: hemi68charger]
#2712515
11/03/19 06:48 PM
11/03/19 06:48 PM
hemi68charger
Houston, Tx
Working on the rear valance mock-up and 4speed hump removal and patch complete
[Re: hemi68charger]
#2721841
12/05/19 09:06 PM
12/05/19 09:06 PM
hemi68charger
Houston, Tx
More updates... We decided to go ahead and replace the taillamp panel as well.... Heard good things about them and what to look for..
Floor in the interior coming along..
Found nearly perfect Monaco/Polara full wheel covers that most of the Press Release cars came with
[Re: hemi68charger]
#2721930
12/06/19 07:50 AM
12/06/19 07:50 AM
Posts: 892 MA
steve70
MA
Great progress....love the hubcaps!
1970 Challenger T/A 4 speed
[Re: gtx6970]
#2722849
12/09/19 11:39 PM
12/09/19 11:39 PM
hemi68charger
Houston, Tx
want to keep as much of the original sheetmetal as possible and reduce the number of welds separated/removed....
There's the houses of keep as much original metal and those to replace the whole component....
[Re: gtx6970]
#2724024
12/14/19 04:56 PM
12/14/19 04:56 PM
Posts: 9,102 Rogue River, OR
Jeremiah
Rogue River, OR
Should look good with the hubcaps on it.
But I have to ask. On the inner wheel houses, Why not use the entire replacement part instead of all the cutting and welding it in as a partial My school of thought has been to hide your "sins" in places that are not paint finished (ie the wheel house). There are a lot of layers to that onion once you start getting into the rocker panel/wheel house (inner&outter), etc. It usually pretty obvious when from the trunk if someone has worked on the wheel house seams. Cool car!
[Re: Jeremiah]
#2729650
01/03/20 01:43 PM
01/03/20 01:43 PM
hemi68charger
Houston, Tx
Well, the ole girl is in good hands with Brian and Ray Reitz over at RF Customs.. There is a strong momentum forward with the car. They are making sure the moldings and gaps are all good, soon the car will be in primer.. Moving along nicely..
[Re: hemi68charger]
#2729651
01/03/20 01:45 PM
01/03/20 01:45 PM
hemi68charger
Houston, Tx
some more... Hopefully in Primer next week with final touches of console brackets to be installed, wire harness tabs and tire jack mounts
Re: Press Release Hemi '69 Charger 500, #614 Restoration
[Re: Morty426]
#2730474
01/06/20 09:24 AM
01/06/20 09:24 AM
Posts: 1,138 Home of the Bluegrass
MoparJunkie
Good stuff right here, Troy! Glad this project is going much smoother. GG
"It takes a Mopar to catch a Mopar” 1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54 2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
