Re: Stage VI Head Porting [Re: AndyF] #2695688
09/09/19 09:38 AM
09/09/19 09:38 AM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Originally Posted by AndyF
Here is a hot street 505 with 10:1 compression, 270 heads, ported Indy intake and a Holley Sniper. It makes 720 hp on pump gas with a Comp street roller cam.
Can you share the rotating assembly specs? On the 270's, is the exhaust port raised and does it create any header problems? Was it built on a 400 or 440 platform?
Re: Stage VI Head Porting [Re: Uberpube] #2695744
09/09/19 11:38 AM
09/09/19 11:38 AM
AndyF Offline
AndyF  Offline
Rotating assembly is off the shelf. I think that engine had a Molnar crank and rods and Diamond pistons. It is a 440 block with a 4.25 stroke crank. The exhaust port on the 270 heads is in the stock location or close to the stock location. I'm not aware of any header problems but who knows, most headers don't fit anyway so how would anyone ever tell?
Re: Stage VI Head Porting [Re: AndyF] #2695933
09/09/19 08:35 PM
09/09/19 08:35 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Thanks Andy., you'll have to do a second edition book with the TF heads.
