Really High idle after warm up on 360 #2693265
08/31/19 08:58 PM
08/31/19 08:58 PM
NJ
dartnj Offline OP
dartnj  Offline OP
NJ
360/ Holley street dominator vac secondaries/auto/MP
Distributor.
Car starts no problem, run fine except once it warmed up the idle will stay high like 2k rpm. Sometimes it slowly comes down to 1100rmp but normally it’s 850ish. Throttle is on the idle screw slack in the throttle cable and kickdown cable.
Any thoughts on what the cause is?
Re: Really High idle after warm up on 360 [Re: dartnj] #2693286
08/31/19 10:46 PM
08/31/19 10:46 PM
throttle is on the idle screw & it can be 850 or 2K RPM? Just a WAG but any possibility that the dist weights are sticking (& advancing the timing)?
Re: Really High idle after warm up on 360 [Re: RapidRobert] #2693307
08/31/19 11:32 PM
08/31/19 11:32 PM
NJ
dartnj Offline OP
dartnj  Offline OP
NJ
Thanks RapidRobert, that’s definitely a possibility. I was thinking it was possibly something with the timing. I’ll pull the distributor cap after I warm up the car and see if there’s anything sticking or binding.
Re: Really High idle after warm up on 360 [Re: dartnj] #2693313
08/31/19 11:53 PM
08/31/19 11:53 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
You didn't inadvertently put the vacuum advance hose on the manifold vacuum port?
Re: Really High idle after warm up on 360 [Re: Sniper] #2693327
09/01/19 01:11 AM
09/01/19 01:11 AM
NJ
dartnj Offline OP
dartnj  Offline OP
NJ
The vac advanced port is plugged/not used.
Re: Really High idle after warm up on 360 [Re: RapidRobert] #2693728
09/02/19 07:03 PM
09/02/19 07:03 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree And will add it could also be due to the advance springs being to light. Get a timing light on it and see what the timing is doing.
Also, is this a new problem with no other changes ?? shruggy
Re: Really High idle after warm up on 360 [Re: TJP] #2693814
09/02/19 11:59 PM
09/02/19 11:59 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
I would check the secondary's are closed all the way.
