Re: Another plug read [Re: mopar dave] #2693675
09/02/19 04:05 PM
09/02/19 04:05 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I know basically nothing about your car except that it's a BB stroker w/ Victor heads and SFT cam.
- Weight w/ driver?
- Gears?
- Tire size / radial or bias?
- Shift RPM?
- Trap RPM?
- Suspension?
- Carb size & type?
- Type intake and any spacer used?
- Air cleaner type & size (if one used)?
- Clearance between top of carb and air cleaner lid or underside of hood?
- Converter flash RPM from launch?
- DA during your most recent runs?
What did the car run in comparable conditions w/ the 408 SB stroker? How much has changed w/ the car since then, besides the engine swap?
I A$$ume there's some carb/ignition/chasssis tuning left on the table. I doubt advancing the cam is going to do much, if anything.
Re: Another plug read [Re: BradH] #2693694
09/02/19 05:17 PM
09/02/19 05:17 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
I was gonna start a new post on this after my next trip to the track, but here go's anyway.
3380# Race weight
4.10 gear
28" M/T ET Radial 325/50
6800 shift
6900 trap
Cal-trac on calvert mono
1100 Thumpercarb with 950 bangos
Indy 400-3 with a 1" Wilson's taper 4 hole
Moroso 3" drop base( ran with and without filter,ran better with. Switch to an air bell and ran better yet. 1" clearance between 6pac hood and air bell)
8" vert 5100 flash 6% slippage
DA I do not know, but humidity was 45% and air temp was 58* on last run
408 ran a best of 10.38@131, only thing different is the 727 trans for big block, but its set up the same and the 60/40 front shocks, had 90/10 calverts.
I'm now thinking the victor mw heads are to blame.
The single pic is my last run for the night.
Re: Another plug read [Re: mopar dave] #2693710
09/02/19 06:22 PM
09/02/19 06:22 PM
Mt Morris Michigan
Mt Morris Michigan
Re: Another plug read [Re: mopar dave] #2693713
09/02/19 06:26 PM
09/02/19 06:26 PM
BradH Offline
BradH  Offline
Originally Posted by mopar dave
1" clearance between 6pac hood and air bell) ==> Sounds too restrictive to me. Have you considered taking off the carb spacer and seeing what happens with more clearance?
I'm now thinking the victor mw heads are to blame. ==> Why?
Re: Another plug read [Re: mopar dave] #2693715
09/02/19 06:30 PM
09/02/19 06:30 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I think the specs on the plug are just carbon off the chamber but would go to 34 to be safer.Keep up the good work.
Re: Another plug read [Re: BradH] #2693717
09/02/19 06:33 PM
09/02/19 06:33 PM
Mt Morris Michigan
Mt Morris Michigan
I did, but without an air cleaner there must be 5" of clearance, but yet with an air bell and 1" it ran better. I will try that this weekend thou.
Re: Another plug read [Re: BradH] #2693721
09/02/19 06:40 PM
09/02/19 06:40 PM
Mt Morris Michigan
Mt Morris Michigan
I'm not sure why, but I have seen no one make big power with these heads. Not many use them either. Not sure what the problem is, trick flow 270's make more power from what I have seen and these have a 330cc port.
Re: Another plug read [Re: Clanton] #2693722
09/02/19 06:41 PM
09/02/19 06:41 PM
Mt Morris Michigan
Mt Morris Michigan
Ok, thanks clanton. I will be running 36* next weekend, I think it ran better.
Re: Another plug read [Re: mopar dave] #2693724
09/02/19 06:48 PM
09/02/19 06:48 PM
Mt Morris Michigan
Mt Morris Michigan
Here's a slip from my pump gas 408 which did have a solid roller, electric fan and pump just to be fair.
Re: Another plug read [Re: mopar dave] #2693860
09/03/19 09:04 AM
09/03/19 09:04 AM
ohio
67mprfan Offline
67mprfan  Offline
ohio
Hello Dave
After watching the video your mph suggest you should be in the 10-20/30 range were you still running
Full exhaust or open headers and what size is it ?
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Another plug read [Re: 67mprfan] #2693872
09/03/19 09:40 AM
09/03/19 09:40 AM
Mt Morris Michigan
Mt Morris Michigan
Full 3.5" exhaust 34" long with a split flow type oval race muffer
