Re: Another plug read
[Re: BradH]
#2693694
09/02/19 05:17 PM
09/02/19 05:17 PM
Posts: 8,046 Mt Morris Michigan
mopar dave
Mt Morris Michigan
I was gonna start a new post on this after my next trip to the track, but here go's anyway. 3380# Race weight 4.10 gear 28" M/T ET Radial 325/50 6800 shift 6900 trap Cal-trac on calvert mono 1100 Thumpercarb with 950 bangos Indy 400-3 with a 1" Wilson's taper 4 hole Moroso 3" drop base( ran with and without filter,ran better with. Switch to an air bell and ran better yet. 1" clearance between 6pac hood and air bell) 8" vert 5100 flash 6% slippage DA I do not know, but humidity was 45% and air temp was 58* on last run 408 ran a best of 10.38@131, only thing different is the 727 trans for big block, but its set up the same and the 60/40 front shocks, had 90/10 calverts. I'm now thinking the victor mw heads are to blame. The single pic is my last run for the night.
[Re: mopar dave]
#2693860
09/03/19 09:04 AM
09/03/19 09:04 AM
Posts: 1,030 ohio
67mprfan
ohio
Hello Dave After watching the video your mph suggest you should be in the 10-20/30 range were you still running Full exhaust or open headers and what size is it ?
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
