Type II power steering box #2692459
08/28/19 11:13 PM
08/28/19 11:13 PM
AndyF Offline OP
AndyF  Offline OP
I've been working on a set of mounts for a Type II PS box to a big block. I think I finally have it figured out. This setup is fairly simple and is very rigid. I'm using 0.188 thick steel and then laser cutting and bending it. Parts are raw right now but I should have finished powder coated parts on hand in a few weeks. I'm also using a low mount 90 amp alternator in this picture. This is the new front accessory setup on the 426W block going into my '65 Coronet.
Re: Type II power steering box [Re: AndyF] #2692466
08/28/19 11:34 PM
08/28/19 11:34 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Looks nice.
Does that alternator position conflict with using a mechanical fuel pump?
Re: Type II power steering box [Re: Kern Dog] #2692574
08/29/19 11:10 AM
08/29/19 11:10 AM
AndyF Offline OP
AndyF  Offline OP
My stuff is EFI so I don't have a mechanical fuel pump.
Re: Type II power steering box [Re: AndyF] #2692647
08/29/19 03:33 PM
08/29/19 03:33 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Can't make it out, is there a square 1/2" breaker bar tensioning hole in the front plate?
Re: Type II power steering box [Re: AndyF] #2692648
08/29/19 03:36 PM
08/29/19 03:36 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Yeah, okay. I thought you were posting to show something that you might decide to produce for sale. EFI builds are getting popular but are still in the minority...Of course you already know that.
Re: Type II power steering box [Re: jcc] #2692707
08/29/19 08:23 PM
08/29/19 08:23 PM
AndyF Offline OP
AndyF  Offline OP
There is a breaker bar hole in the front plate but it is 3/8 not 1/2.
Re: Type II power steering box [Re: Kern Dog] #2692708
08/29/19 08:26 PM
08/29/19 08:26 PM
AndyF Offline OP
AndyF  Offline OP
I do sell a low mount 60 amp kit. A lot of cars are electric pump these days. Even if people still have a carb one of the new EFI tanks with a high pressure regulator is a better system than a mechanical pump. http://arengineering.com/products/low-mount-60a-kit-bb/
Re: Type II power steering box [Re: AndyF] #2692746
08/29/19 10:08 PM
08/29/19 10:08 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Looks good, I have a TypeII box on my Hemi, it's working out pretty decently.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Type II power steering box [Re: GoodysGotaCuda] #2692839
08/30/19 10:33 AM
08/30/19 10:33 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
we use the type box on all of our serpentine kits. been using them for years. these are also known as the zf box and you can get them in a ton of different configurations and reservoir options including remote mount reservoirs. no problems running the mopar gear boxes and they are small and light weight.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Type II power steering box [Re: Jerry] #2692927
08/30/19 02:43 PM
08/30/19 02:43 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
Not intending to take away from the OP... but what advantages are there to this "Type II" ps pump?
How does it compare to a desired Saginaw pump that has proper response to quick demand L/R/L/R/ hi-rpm power assist (whereby the Federal ps pump does not)?
Is there a Type II ps pump available for SB engines?
Re: Type II power steering box [Re: Mopar Mitch] #2692980
08/30/19 05:58 PM
08/30/19 05:58 PM
AndyF Offline OP
AndyF  Offline OP
Check out a couple of these websites and you'll see that the aftermarket has moved on from the older pumps.
https://www.tuffstuffperformance.com/c-1267414-general-motors-power-steering-pumps-type-ii.html
https://www.krcpower.com/
Re: Type II power steering box [Re: Mopar Mitch] #2694181
09/03/19 11:44 PM
09/03/19 11:44 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
These are the pump the late model circle track cars use.
Some stock setups have aluminum pumps cases boogie
And aftermarket offers many in aluminum cases with variations in pump psi and flow. And IIRC there are kits to change psi and/or flow.
Look at the KRC line.
Also, you can run remote reservoirs. And mount them low.
But bummer, I don’t know of a Small Block Mopar bracket setup for a LA small block.
Re: Type II power steering box [Re: autoxcuda] #2694297
09/04/19 11:33 AM
09/04/19 11:33 AM
AndyF Offline OP
AndyF  Offline OP
I'm sure something could be fabricated for a SB Mopar. I ended up building my own brackets for the BB engine. I started off buying the bracket kit from Unisteer but after I bolted it on I decided it was too crappy of a design to use on my car. The type II pump is very bracket friendly. It has bolt holes that go thru the pump and the mounting surfaces are flat so it is very easy to fabricate mounting plates.
Re: Type II power steering box [Re: autoxcuda] #2694381
09/04/19 02:38 PM
09/04/19 02:38 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
I have a small, oval track style pump similar to the KRC unit linked above. I was able to utilize some stock SB brackets by modifying the bends slightly and adding a spacer behind the backing bracket. I have a divorced reservoir sitting on the inner fender. I've contemplated adding a cooler to it as well as all I need is the cooler and more hose and ends.
I don't think it would be a big stretch to figure out what else needed to be added to set a type 2 pump above the pump. In fact, I'd bet if you mock it up using some scrap steel welded together, you could take the completed unit to a local oval track fab shop with punch/laser/brake capability and have them make a fancy looking, single piece copy of your mock up. you could get it powdercoated or chromed, or if made from aluminum, anodized. Viola, fancy bracket. you might even be able to sell 3, or 4 to offset some of the cost.
Re: Type II power steering box [Re: AndyF] #2695139
09/07/19 09:13 AM
09/07/19 09:13 AM
nj
JAMESDART Offline
JAMESDART  Offline
nj
Nice, I'll be looking for one of the ps brackets when I have some play money.
Re: Type II power steering box [Re: JAMESDART] #2699974
09/22/19 09:46 PM
09/22/19 09:46 PM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
Nice work as always Andy. If you ever make one for a smallblock, I'll buy it. Same for those trick billet timing covers you once offered, too bad they were not a big seller. I should have bought one when they were available. perhaps, if that program is available for purchase? Maybe I could send that to a CNC guy to have one made...
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: Type II power steering box [Re: mopardude318] #2700271
09/23/19 09:03 PM
09/23/19 09:03 PM
Jamey Offline
Jamey  Offline
Re: Type II power steering box [Re: Jamey] #2700639
09/25/19 12:41 AM
09/25/19 12:41 AM
AndyF Offline OP
AndyF  Offline OP
Not much information on that KRC bracket! That has to be one of the most ineffective ads for a part that I've seen. Basically zero info.
Re: Type II power steering box [Re: AndyF] #2700857
09/25/19 04:53 PM
09/25/19 04:53 PM
Mountain View, CA
68rrunner Offline
68rrunner  Offline
Mountain View, CA
They work. EMax runs that setup. I don't have any pictures, but you can see it with a quick internet search. 9 years and going strong.
Re: Type II power steering box [Re: AndyF] #2702391
09/30/19 08:20 PM
09/30/19 08:20 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Andy I just started a thread in the Q&A section about power steering and a member directed me to this thread.
Looks interesting. Will this setup work with a motor plate?
Would I just have to run one hose from the Type II pump to the power steering rack, or is it 2 hoses?
I was looking at the Saginaw pump and brackets on Mancini's website but I have no knowledge or experience with power steering.
