Re: FACTORY CYLINDER THEORY AND CAM SPECS
[Re: A/MP]
#2689071
08/18/19 12:59 PM
08/18/19 12:59 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I’m not sure what you’re saying, but the fastest of the SB Mopar Stockers all use the high lift cam....... the C/D/E/F cars.
[Re: A/MP]
#2689089
08/18/19 02:03 PM
08/18/19 02:03 PM
Posts: 4,209 New York
polyspheric
New York
The Chrysler cam design has many more variables than max power with a specific port. Included is the always popular "how cheaply can we make it".
Boffin Emeritus
[Re: Scully]
#2689994
08/21/19 11:57 AM
08/21/19 11:57 AM
Posts: 608 TN
1DGEMAN
TN
Any body that has run a Stock Eliminator 340 knows those cam specs were Mopars imagination. In 72 the piston went from .045 above to .054 down. head gasket went from .032 to .036 and intake valve went from 303 to 1.88.
Real Men shift for themselves
[Re: 1DGEMAN]
#2690409
08/22/19 05:20 PM
08/22/19 05:20 PM
Posts: 498 El Dorado Ca
65signet
El Dorado Ca
I believe the ports on the 308 heads are smaller than the earlier heads, and its more about velocity in the port regardless of of lift, and the duration is what makes the power. just my opinion.
1965 Plymouth Barracuda 273 M/SA 1970 Plymouth Duster 360/904 10.60s with J heads
