Re: header gaskets ?
[Re: dafixr]
#2687557
08/14/19 08:53 AM
08/14/19 08:53 AM
Posts: 4,457 Washington
madscientist
Washington
What is the best header gasket to use. Street use Have copper now but leaks even with high temp silicone. Headers are cut in between to float Thanks Remflex. They'll seal almost anything.
[Re: dafixr]
#2687650
08/14/19 11:54 AM
08/14/19 11:54 AM
Posts: 350 Mequon, WI
gzig5
Mequon, WI
Can we get from Jegs or Summit?
Thanks You have a computer. You can go on their sites and see if they carry them for your application or call them. Come on man!
[Re: Cab_Burge]
#2687662
08/14/19 12:15 PM
08/14/19 12:15 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
I've used a body board and 80 grit to knock down the high spots on the flanges before, if its an issue. As mentioned above, Remflex is the only way to go.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#2687706
08/14/19 01:30 PM
08/14/19 01:30 PM
Posts: 5,166 CT
GTX MATT
CT
Percy's dead soft aluminum has worked great for me
[Re: 451Mopar]
#2687731
08/14/19 03:16 PM
08/14/19 03:16 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Regardless what gasket you use, IF the two mating surfaces are not clean and flat, or else if the threadings are not clean and free of debris, then no gasket will seal properly. Occasional retorquing is advisable due to the weakness and vibrations of tubular headers. Always inspect the surface flanges of the headers -- they are notorious to have flaws and poor surface flatness (at the welds of the tubes into the flange).
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Mopar Mitch]
#2687740
08/14/19 04:01 PM
08/14/19 04:01 PM
Posts: 20,730 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
Copper gaskets and copper rtv should cover it unless your sealing surfaces are uneven.
I ink up the flanges and file them in an x-pattern with a wide file until the ink is gone.
