Re: 71 B Body A/C Heater Valve ID [Re: scatcity] #2689693
08/20/19 11:03 AM
08/20/19 11:03 AM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Open to the air wasn't what I was referring to. It is a vacuum leak and when trying to find a vacuum problem leaks don't help. Now that you replaced the valve and hooked the hose up it doesn't matter.
Re: 71 B Body A/C Heater Valve ID [Re: scatcity] #2689863
08/20/19 09:29 PM
08/20/19 09:29 PM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
I don't know if I can adequately describe how the vacuum control switch works, but I will try. There are seven vacuum nipples, one of which is connected to engine vacuum, the others to the various actuators. Behind those nipples is a sliding plastic block sealed with grease against the backside of the seven vacuum ports/nipples. As you move the selector, the lever slides the plastic block back and forth changing which port gets engine vacuum. On the side (top or bottom, I forget) of the sliding block are three ramps which ride across three electrical contacts. This changes which plugs on the five-way electrical connector are live. Off of the main vacuum harness, one of the hoses tees off and connects to the back of the heater controls to provide vacuum to the variable control from which the the other hose goes to the water valve.
The vacuum nipples get brittle with age and break off.
Re: 71 B Body A/C Heater Valve ID [Re: 71charger] #2689998
08/21/19 12:08 PM
08/21/19 12:08 PM
Morningside, Long Island
scatcity Offline OP
scatcity  Offline OP
Your explanation is perfect, thanks
I have a few spares so diagnostics hopefully go well. Appreciate the input.
Re: 71 B Body A/C Heater Valve ID [Re: scatcity] #2690732
08/23/19 08:12 PM
08/23/19 08:12 PM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
Here are the guts of a '71 Charger heater/AC switch.
Re: 71 B Body A/C Heater Valve ID [Re: 71charger] #2691122
08/25/19 08:03 AM
08/25/19 08:03 AM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
This one was still working? Looks good inside....
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: 71 B Body A/C Heater Valve ID [Re: DynoDave] #2691146
08/25/19 10:18 AM
08/25/19 10:18 AM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
All the nipples were broken off, so I sacrificed it to take some photos of how it works.
