internal balance Q #2687377
08/13/19 05:43 PM
08/13/19 05:43 PM
RapidRobert Offline OP
65 D100 /6. swapping in a BB. Have the correct BB (early 60's I am assuming) hyd bell/wheel/ NP 435 granny 4 speed etc. I am assuming this 'wheel is internally balanced. I have a 400 & a 440 & the torque converters on both of em have the extra weights denoteing externally balanced (I am assuming). Is there any way I can get one of these engines to drop in as is or do I need to find an earlier internally balanced 440? Thank you for your time.
Re: internal balance Q [Re: RapidRobert] #2687653
08/14/19 12:03 PM
08/14/19 12:03 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
If they are externally balanced you will either have to get the flywheel modified or find a steel crank engine or install a steel crank in yours. Somebody used to make a weight that sandwiched between the crank and the flywheel but I'm not sure who made it or if it's still available.
Externally balanced engines also have a different harmonic balancer too just in case someone installed a different transmission in the past and didn't know there was a difference. Cast cranks usually aren't drilled properly for a pilot bushing either.
Kevin
Re: internal balance Q [Re: RapidRobert] #2687688
08/14/19 01:02 PM
08/14/19 01:02 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
If you can get your hands the latest edition of Mopar Action, there is a tech article about this very thing...
It gives a number of options one of which is mentioned above.
Re: internal balance Q [Re: Jwilli500] #2687789
08/14/19 07:01 PM
08/14/19 07:01 PM
Twostick, the 400/440 both appear to be unmolested engines & have the ext balance pads on their respective torque converters. Jwilli I just called Barnes & Noble & they have the Oct issue on the shelf so I will pick it up tomorrow. Now to find a good steel crank 440 (I am assuming). thanks guys!
Re: internal balance Q [Re: RapidRobert] #2688011
08/15/19 12:34 PM
08/15/19 12:34 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
So your not going to use one of the externally balanced motors? Steel crank would be Internally ballanced.
Re: internal balance Q [Re: RapidRobert] #2688071
08/15/19 03:17 PM
08/15/19 03:17 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The flywheel external weight is the same for both the cast crank 400 and 440. Just drill the flywheel as in the lower diagram below and you're good to go.
