Thanks for all the great feedback on this. Looks like the order of business here might be:
1) To make sure the mounts are not the issue, get a set of the correct Schumachers to ensure the motor change adaptation. These should get the motor to the proper height at least and even get it halfway straight, if that is possible. As was said earlier, it may make the interference to the steering shaft even worse.
2) If #1 doesn't work out totally, get a set of HP manifolds for the 440.
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor
1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic
1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow
1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top
2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue
2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black
2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
