Re: Clutch for '69 Roadrunner
[Re: VITC_GTX]
#2684496
08/04/19 11:14 PM
08/04/19 11:14 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
Let's try to say this without upsetting the purists. 1st of all, if the car needs to stay correct. No choice but to go Borg n Beck, it's proper.
Now onto the facts. All 3 finger set ups are old technology. The pedal has the most spring pressure at the wrong time, when it's released. The least amount when the clutch is engaged. So if the disc slips you need to add more spring pressure. What happens is you get a tiny bit more on the disc but mostly on your left leg.
A diaphram style places most of it's pressure on the disc while it's clamped. Basically it goes over center when it's released making the same pressure plate that can contain alot of power, easy to disengage.
Centerforce for me.
[Re: pro451bee]
#2684552
08/05/19 07:40 AM
08/05/19 07:40 AM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
Center Force in my 65 440 also.Light pedal and hooks great.Been in for years and has been used and abused.Still like the day it went in.Did run McCleod B&Bs for years.Never will go back.Rocky
Chrysler Firepower
[Re: VITC_GTX]
#2684751
08/05/19 05:06 PM
08/05/19 05:06 PM
Posts: 784 Florida
cbusters
Sounds like most folks like the diaphragm style clutches, thanks.
I've looked at a few mentioned here and they are pretty spendy. I do understand the old adage " you get what you pay for " but for a completely stock engine would I be off-base to go out to NAPA or Rock Auto and get a clutch kit for $150?? This will be a 100% street car/daily driver. Or have yours rebuilt.
[Re: VITC_GTX]
#2684809
08/05/19 10:12 PM
08/05/19 10:12 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
I've looked at a few mentioned here and they are pretty spendy. I do understand the old adage " you get what you pay for " but for a completely stock engine would I be off-base to go out to NAPA or Rock Auto and get a clutch kit for $150?? This will be a 100% street car/daily driver. The old adage is never more fitting for a certain part more than a clutch. Roll the dice on a $150 clutch and it MIGHT work spend about $400-500 and it will last and work. I have $450 in a Centerforce II plate with Mcleod 500 series disc and it works very well for a street clutch. The car weighs 3550* with me in it and I have a 493 with lots of torque and it 's smooth and holds very well even under full throttle and it doesn't care where I drive it. Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: VITC_GTX]
#2684921
08/06/19 11:04 AM
08/06/19 11:04 AM
Posts: 935 Elizabethtown, KY
6T9Hemi
Elizabethtown, KY
Don't forget to have the flywheel faced...................very important on new clutch installation.
1969 340 4 Speed Swinger R4, black vinyl, white butt stripe, 3:91
[Re: 6T9Hemi]
#2685001
08/06/19 03:00 PM
08/06/19 03:00 PM
Posts: 15,536 Omaha Ne
TJP
Omaha Ne
Don't forget to have the flywheel faced...................very important on new clutch installation. Agreed at a minimum. However, I have read articles that recommend replacing as flywheels purportedly develop hard spots from excess heat. These spots which are clearly visible before facing are hidden by the process. They then again, purportedly resurface and cause problems with the disc seating / grabbing. Don't know about the truth to the above but figured I'd pass it along. We have had no issues with resurfacing on a stock low power application but have never tried it on a performance application, they have always gotten new flywheels. Maybe someone else with a bit more information will chime in ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
