E20 afr targets #2683815
08/02/19 08:19 PM
08/02/19 08:19 PM
South Dakota
W
wireweld Offline OP
wireweld  Offline OP
W
South Dakota
I’m using a Fitech 1200 pa and running E20 fuel. What should I set my afr targets?
Re: E20 afr targets [Re: wireweld] #2683829
08/02/19 08:44 PM
08/02/19 08:44 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Depends on what you have your stoichiometric ratio is at.
If you didnt change any of the default settings 12.8-13.1 should be your target value.
Re: E20 afr targets [Re: Sammy] #2683933
08/03/19 07:25 AM
08/03/19 07:25 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
My understanding is you can use the same targets it will just take more fuel to get there.
For what's its worth my car is port fuel injected and it doesn't care E0-E10. I don't change the tune and it doesn't change the time slip.
68 Barracuda Formula S 340
Re: E20 afr targets [Re: wireweld] #2683957
08/03/19 08:59 AM
08/03/19 08:59 AM
New York
polyspheric Offline
polyspheric  Offline
New York
For an emissions test in a lab, stoichiometric ratio is useful. It means that the mixture contains exactly as much oxygen as needed to completely burn every molecule of fuel: no more, no less. The result is water and carbon dioxide only.
This is not what a car engine does (completely burn fuel, supra), and that number is not optimum for any particular RPM, vacuum, throttle position, spark position, or power level. Best WOT is always richer than stoich, cruising is leaner, it should vary throughout the range depending on conditions.
Boffin Emeritus
Re: E20 afr targets [Re: polyspheric] #2685926
08/09/19 08:53 AM
08/09/19 08:53 AM
South Dakota
W
wireweld Offline OP
wireweld  Offline OP
W
South Dakota
Should I increase cubic inches by 5-7% to increase fuel like when using e85?
