Re: Billet Main Caps?
[Re: hudsonhornet7x]
#2683040
07/31/19 11:00 AM
07/31/19 11:00 AM
Posts: 194 Springtown Pa
Ray408G3Hemi
Springtown Pa
My builder says over 650 hp it's a good idea, at 750 Hp it' better idea,800 it's a requirement. I know he uses them on all of the 4.25 stroke builds he's done. My 408Ci (5.7 based) makes 725 hp and has a older set of Pro-Gram , which now are manufactured/sold by Billet Speed works.
1963 Thunderbolt 496FE 10.80 (still a work in progress) 1968 Mustang slow a$$ 428 FE 1971 Boss 351 Mustang 11.20@115mph 1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA 1996 Viper GTS 2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor 2009 Ram 9.65@144MPH 463CI G3 NA 2010 Challenger 9.91 @ 139MPH 408CI G3ci NA 2019 F150 (local dealer's Lightning package) ..11.90s
[Re: Ray408G3Hemi]
#2683083
07/31/19 12:42 PM
07/31/19 12:42 PM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
The demon is 840 HP with regular caps.
[Re: HotRodDave]
#2683104
07/31/19 01:25 PM
07/31/19 01:25 PM
Ray408G3Hemi
Springtown Pa
The demon is 840 HP with regular caps. And your point is? if you are going to invest 5-12k into a new engine spend the money for every bit of insurance. Demon also doesn't have ARP mains or Rod bolts......are you going to tell me just because that 8XX hp engine doesn't use them you won't? Demon blows up ...you go back to the dealer for warranty. Hudsonshornet's engine takes a crap because the mains walked or he decided to go with stock rod bolts because the Demon uses them? .....where is he going to go for warranty ?
[Re: Ray408G3Hemi]
#2683138
07/31/19 03:32 PM
07/31/19 03:32 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
We recommend them over the 750HP mark, or anything getting a power adder that way when the customer gets bored and turns it up, the caps are there.
Brian Hafliger
[Re: Ray408G3Hemi]
#2683426
08/01/19 12:54 PM
08/01/19 12:54 PM
HotRodDave
Kalispell Mt.
The demon is 840 HP with regular caps. And your point is? if you are going to invest 5-12k into a new engine spend the money for every bit of insurance. Demon also doesn't have ARP mains or Rod bolts......are you going to tell me just because that 8XX hp engine doesn't use them you won't? Demon blows up ...you go back to the dealer for warranty. Hudsonshornet's engine takes a crap because the mains walked or he decided to go with stock rod bolts because the Demon uses them? .....where is he going to go for warranty ? The factory would be upgrading if it was a concern because they don't want to replace engines because of those caps, "if they were a problem". I just think they are pointless under 800 HP. I am all for upgrading weak links, I just don't see them being a weak link. The things that were weak links on engines of past (aluminum mains on BB anybody) tend to be though of as weak links on modern engines even though the factory adressed them and they are no longer an issue, same as how we no longer need aftermarket ported heads for 600HP engines. If you start going over 800 HP then maybe upgrade the caps butt honestly I have never heard of a main cap breaking on one of these at any level and plenty of people are adding boost and nitrous to these things without opening the motor.
#2683588
08/02/19 08:00 AM
08/02/19 08:00 AM
Posts: 577 Arkansas
Adrielp
Arkansas
How many companies are making billet main caps for the gen 3 hemi? Anyone have feedback on each companies quality?
Adriel Paradise Substation Design Engineer III
[Re: Adrielp]
#2683635
08/02/19 10:48 AM
08/02/19 10:48 AM
Ray408G3Hemi
Springtown Pa
How many companies are making billet main caps for the gen 3 hemi? Anyone have feedback on each companies quality? I Know Arrington sells their own, Not sure who makes them, I've seen a few setts and they look good, My builder has used them a few times ...he just shrugs his shoulders and says ...There Main caps. I have older pro-gram caps in my G3 can't complain .we freshened up the short block this past February after 18k miles and 500 runs and the only marks in the DLC coated Mains bearings was from the Dial bore gauge from the initial build.
[Re: L4staero]
#2683638
08/02/19 10:53 AM
08/02/19 10:53 AM
Ray408G3Hemi
Springtown Pa
Main caps do break. If you have ever seen how porous these G3 caps are u will understand why they break.
I say if you have a power adder its good insurance. Im in the process of getti g a production run of billet main caps done.
Also the Demon engine has ARP rod bolts I've seen a few 650-700 Hp G3s pulled apart with either #2 or #3 Broken at the stud like the one you have in that photo, as for the Demon.....I've seen my builder tear 4 of them apart so far and looks like the factory must of missed them Memo on on the ARP main studs.
[Re: 496 A-body]
#2683666
08/02/19 12:18 PM
08/02/19 12:18 PM
Ray408G3Hemi
Springtown Pa
Slowly whittling a set for myself, if accurately made the only required machine work should be an align hone, which you would do if installing studs anyway. They look good, the bolt in the center is that for a girdle ?
[Re: L4staero]
#2683701
08/02/19 02:05 PM
08/02/19 02:05 PM
HotRodDave
Kalispell Mt.
Also the Demon engine has ARP rod bolts Looking at the heat scoring on the other caps I would say something else was going on and the broken cap was probably the result of something else.
[Re: Jwilli500]
#2683727
08/02/19 03:11 PM
08/02/19 03:11 PM
Posts: 369 Indy
496 A-body
Indy
I imagine that is to screw in a slide hammer to pop the caps out of the block at disassembly. That would be correct
[Re: HotRodDave]
#2683867
08/02/19 10:15 PM
08/02/19 10:15 PM
Posts: 146 Australia
L4staero
Australia
Also the Demon engine has ARP rod bolts Looking at the heat scoring on the other caps I would say something else was going on and the broken cap was probably the result of something else. The engine had nothing else fail but the cap. It was a pullied up Hellcat
[Re: Ray408G3Hemi]
#2683874
08/02/19 10:29 PM
08/02/19 10:29 PM
L4staero
Australia
Also the Demon engine has ARP rod bolts I've seen a few 650-700 Hp G3s pulled apart with either #2 or #3 Broken at the stud like the one you have in that photo, as for the Demon.....I've seen my builder tear 4 of them apart so far and looks like the factory must of missed them Memo on on the ARP main studs. No not ARP main studs just ARP rod bolts
