Billet Main Caps? #2682770
07/30/19 05:25 PM
07/30/19 05:25 PM
USA
hudsonhornet7x Offline OP
USA
When we talk about building these gen III engines the discussion comes to ARP studs in the bottom end. Everyone agrees that these studs are a good idea. If you are building one of these things for a power adder like a supercharger, when are billet main caps a good idea? Is the added expense of purchasing the caps and then machining worth the benefit?
Re: Billet Main Caps? [Re: hudsonhornet7x] #2683040
07/31/19 11:00 AM
07/31/19 11:00 AM
Springtown Pa
Ray408G3Hemi Offline
Springtown Pa
My builder says over 650 hp it's a good idea, at 750 Hp it' better idea,800 it's a requirement. I know he uses them on all of the 4.25 stroke builds he's done. My 408Ci (5.7 based) makes 725 hp and has a older set of Pro-Gram , which now are manufactured/sold by Billet Speed works.
1963 Thunderbolt 496FE 10.80 (still a work in progress)
1968 Mustang slow a$$ 428 FE
1971 Boss 351 Mustang 11.20@115mph
1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA
1996 Viper GTS
2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor
2009 Ram 9.65@144MPH 463CI G3 NA
2010 Challenger 9.91 @ 139MPH 408CI G3ci NA
2019 F150 (local dealer's Lightning package) ..11.90s
Re: Billet Main Caps? [Re: Ray408G3Hemi] #2683083
07/31/19 12:42 PM
07/31/19 12:42 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The demon is 840 HP with regular caps.
Re: Billet Main Caps? [Re: HotRodDave] #2683104
07/31/19 01:25 PM
07/31/19 01:25 PM
Springtown Pa
Springtown Pa
And your point is?
if you are going to invest 5-12k into a new engine spend the money for every bit of insurance.
Demon also doesn't have ARP mains or Rod bolts......are you going to tell me just because that 8XX hp engine doesn't use them you won't?
Demon blows up ...you go back to the dealer for warranty.
Hudsonshornet's engine takes a crap because the mains walked or he decided to go with stock rod bolts because the Demon uses them? .....where is he going to go for warranty ?
1996 Viper GTS
Re: Billet Main Caps? [Re: Ray408G3Hemi] #2683138
07/31/19 03:32 PM
07/31/19 03:32 PM
SoCal
Brian Hafliger Offline
SoCal
We recommend them over the 750HP mark, or anything getting a power adder that way when the customer gets bored and turns it up, the caps are there.
Brian Hafliger
Re: Billet Main Caps? [Re: hudsonhornet7x] #2683154
07/31/19 04:47 PM
07/31/19 04:47 PM
Indy
496 A-body Offline
496 A-body  Offline
Indy
Slowly whittling a set for myself, if accurately made the only required machine work should be an align hone, which you would do if installing studs anyway.
Re: Billet Main Caps? [Re: Ray408G3Hemi] #2683426
08/01/19 12:54 PM
08/01/19 12:54 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
And your point is?
The factory would be upgrading if it was a concern because they don't want to replace engines because of those caps, "if they were a problem". I just think they are pointless under 800 HP. I am all for upgrading weak links, I just don't see them being a weak link. The things that were weak links on engines of past (aluminum mains on BB anybody) tend to be though of as weak links on modern engines even though the factory adressed them and they are no longer an issue, same as how we no longer need aftermarket ported heads for 600HP engines. If you start going over 800 HP then maybe upgrade the caps butt honestly I have never heard of a main cap breaking on one of these at any level and plenty of people are adding boost and nitrous to these things without opening the motor.
Re: Billet Main Caps? [Re: HotRodDave] #2683577
08/02/19 03:56 AM
08/02/19 03:56 AM
Australia
L4staero Offline
L4staero  Offline
Australia
Main caps do break.
If you have ever seen how porous these G3 caps are u will understand why they break.
I say if you have a power adder its good insurance.
Im in the process of getti g a production run of billet main caps done.
Also the Demon engine has ARP rod bolts
Re: Billet Main Caps? [Re: hudsonhornet7x] #2683588
08/02/19 08:00 AM
08/02/19 08:00 AM
Arkansas
Adrielp Offline
Adrielp  Offline
Arkansas
How many companies are making billet main caps for the gen 3 hemi? Anyone have feedback on each companies quality?
Adriel Paradise
Substation Design Engineer III
Re: Billet Main Caps? [Re: Adrielp] #2683635
08/02/19 10:48 AM
08/02/19 10:48 AM
Springtown Pa
Springtown Pa
I Know Arrington sells their own, Not sure who makes them, I've seen a few setts and they look good, My builder has used them a few times ...he just shrugs his shoulders and says ...There Main caps.
I have older pro-gram caps in my G3 can't complain .we freshened up the short block this past February after 18k miles and 500 runs and the only marks in the DLC coated Mains bearings was from the Dial bore gauge from the initial build.
1996 Viper GTS
Re: Billet Main Caps? [Re: L4staero] #2683638
08/02/19 10:53 AM
08/02/19 10:53 AM
Springtown Pa
Springtown Pa
Originally Posted by L4staero
Main caps do break.
I've seen a few 650-700 Hp G3s pulled apart with either #2 or #3 Broken at the stud like the one you have in that photo, as for the Demon.....I've seen my builder tear 4 of them apart so far and looks like the factory must of missed them Memo on on the ARP main studs.
1996 Viper GTS
Re: Billet Main Caps? [Re: 496 A-body] #2683666
08/02/19 12:18 PM
08/02/19 12:18 PM
Springtown Pa
Springtown Pa
They look good, the bolt in the center is that for a girdle ?
1996 Viper GTS
Re: Billet Main Caps? [Re: Ray408G3Hemi] #2683694
08/02/19 01:45 PM
08/02/19 01:45 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
I imagine that is to screw in a slide hammer to pop the caps out of the block at disassembly.
Re: Billet Main Caps? [Re: L4staero] #2683701
08/02/19 02:05 PM
08/02/19 02:05 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Main caps do break.
Looking at the heat scoring on the other caps I would say something else was going on and the broken cap was probably the result of something else.
Re: Billet Main Caps? [Re: Jwilli500] #2683727
08/02/19 03:11 PM
08/02/19 03:11 PM
Indy
496 A-body Offline
496 A-body  Offline
Indy
That would be correct
Re: Billet Main Caps? [Re: 496 A-body] #2683732
08/02/19 03:19 PM
08/02/19 03:19 PM
Indy
496 A-body Offline
496 A-body  Offline
Indy
The powdered metal caps on every block I have taken apart have not impressed me. The parting line surface is not machined after sintering and when I set them on a surface plate they had a fair amount of rock. Even on a stock rebuild I would dust that surface and then align hone.
Re: Billet Main Caps? [Re: HotRodDave] #2683867
08/02/19 10:15 PM
08/02/19 10:15 PM
Australia
L4staero Offline
L4staero  Offline
Australia
Main caps do break.
The engine had nothing else fail but the cap. It was a pullied up Hellcat
Re: Billet Main Caps? [Re: Ray408G3Hemi] #2683874
08/02/19 10:29 PM
08/02/19 10:29 PM
Australia
L4staero Offline
L4staero  Offline
Australia
Main caps do break.
No not ARP main studs just ARP rod bolts
Re: Billet Main Caps? [Re: L4staero] #2688591
08/16/19 10:38 PM
08/16/19 10:38 PM
Southern Alberta
Uberpube Online content
Uberpube  Online Content
Southern Alberta
Are the Arrington caps the only ones that don't require align boring? My local machine shop does not have the boring machine, just an align hone.
Re: Billet Main Caps? [Re: Uberpube] #2688782
08/17/19 04:20 PM
08/17/19 04:20 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
I purchased Arrington caps and they had to be line bored. I bought them because it said line hone only. They were a good .060 small. I would call and verify line hone only.
