Do these bore #'s look good? #2682550
07/29/19 10:32 PM
07/29/19 10:32 PM
USA
hudsonhornet7x Offline OP
USA
This is a 400 block for sale. Here are the bore numbers. How does this look to you guys? I am trying to learn to see if it is worth building.
Re: Do these bore #'s look good? [Re: hudsonhornet7x] #2682558
07/29/19 10:57 PM
07/29/19 10:57 PM
What is the bottom number on #6 on the outside of that cylinder?
If it is above.200 I would be glad to use it in a heartbeat up
How far are you wanting to bore it out to,+.030,+.040, +.060 or what size?
Re: Do these bore #'s look good? [Re: Cab_Burge] #2682562
07/29/19 11:04 PM
07/29/19 11:04 PM
USA
USA
Thanks Cab. I don't know what that number is. Best guess is .456 but I don't think that makes sense.
This was e-mailed to me and it is the best pic I have at the moment.
I would bore this out as little as possible.
Re: Do these bore #'s look good? [Re: hudsonhornet7x] #2682574
07/30/19 12:38 AM
07/30/19 12:38 AM
New York, USA
Chargerfan68 Offline
New York, USA
Not that i’m experienced enough with sonic testing or owning a large sample of blocks, but can those numbers be right?? I’ve never heard of bore thickness in the .600” range. Or even .500”+ for that matter within a stock block. I could be totally off base, but i thought some of the afternarket blocks are proud to have .300”+.
Re: Do these bore #'s look good? [Re: Chargerfan68] #2682584
07/30/19 01:49 AM
07/30/19 01:49 AM
A727Tflite Offline
A727Tflite  Offline
Why no readings for the thrust face on #2?
Re: Do these bore #'s look good? [Re: A727Tflite] #2682620
07/30/19 09:13 AM
07/30/19 09:13 AM
Washington
hemienvy Offline
hemienvy  Offline
Washington
For what it's worth, those numbers appear to me to be large by a factor of two.
The machine or the operator recorded doubled values ?
Re: Do these bore #'s look good? [Re: hudsonhornet7x] #2682626
07/30/19 09:44 AM
07/30/19 09:44 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Just my humble opinion.... these numbers seem too good to be true.
Rich H.
Esse Quam Videri
Re: Do these bore #'s look good? [Re: ZIPPY] #2682634
07/30/19 09:58 AM
07/30/19 09:58 AM
Springtown Pa
Ray408G3Hemi Offline
Springtown Pa
I can tell you there are double what the 400 that was in my daughters 76,D100 are
1963 Thunderbolt 496FE 10.80 (still a work in progress)
1968 Mustang slow a$$ 428 FE
1971 Boss 351 Mustang 11.20@115mph
1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA
1996 Viper GTS
2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor
2009 Ram 9.65@144MPH 463CI G3 NA
2010 Challenger 9.91 @ 139MPH 408CI G3ci NA
2019 F150 (local dealer's Lightning package) ..11.90s
Re: Do these bore #'s look good? [Re: hudsonhornet7x] #2682639
07/30/19 10:08 AM
07/30/19 10:08 AM
gregsdart Offline
gregsdart  Offline
I wouldn't touch this unless seller agrees to a sonic test, and he eats it if the block falls below usable limits. If it passes, you pay for sonic check, all negotiable anyway.
Re: Do these bore #'s look good? [Re: hudsonhornet7x] #2682645
07/30/19 10:13 AM
07/30/19 10:13 AM
Nevada
merpar Offline
merpar  Offline
Nevada
If something appears too good to be true. Don't trust it! I would take the block somewhere else and have it checked. Exact same thing happened to me. Had a block sonic checked and numbers were really good. Had it bored to 4.400 assembled the motor. But didn't install, I came across a good deal on a KB solid low deck. So I sold the short block to a guy in Cal.. Months later I got a call from the guy . He had the motor dynoed and it blew up on the dyno. The cylinder walls were paper thin. Lesson to be learned, if you have a block sonic checked. Make sure the equipment they are using is of top quality, not chinese junk. If it checks out too good to be true. Don't use it.
Re: Do these bore #'s look good? [Re: merpar] #2682675
07/30/19 11:37 AM
07/30/19 11:37 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
i don't think the tester was calibrated correctly. pie in the sky numbers.
Re: Do these bore #'s look good? [Re: lewtot184] #2682682
07/30/19 11:54 AM
07/30/19 11:54 AM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
Something is not right, the theoretical max wall thickness between 2 adjacent cylinders would be .458 if siamese, the sum of the wall thicknesses on several adjacent cylinders is higher than .458
Re: Do these bore #'s look good? [Re: GTS340] #2682683
07/30/19 11:59 AM
07/30/19 11:59 AM
USA
USA
Thank you all for confirming my suspicions. This is a " 230" cold weather block 400. The one with the huge main saddles. I was looking at this last night online and could not believe the numbers, but I am not an expert so I thought I would ask here.
Re: Do these bore #'s look good? [Re: hudsonhornet7x] #2682699
07/30/19 12:39 PM
07/30/19 12:39 PM
I bought a early casting cold weather 400 block from AndyF, he had it sonic tested and I retested it with my Dakota 1000 tester, the thinnest place on the worst cylinder wall was .167 down low shruggy
The thickest was around .350, that block clean up at 4.350 and was still running good after 5 years of running it in my S/P car on E85 with no top end lube work
Re: Do these bore #'s look good? [Re: hudsonhornet7x] #2682707
07/30/19 01:00 PM
07/30/19 01:00 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
The numbers are thicker than a World block....
I don't want to be negative...so I'd say...Hey, anything is possible!
Except that...that isn't grin
Rich H.
Esse Quam Videri
Re: Do these bore #'s look good? [Re: hudsonhornet7x] #2682820
07/30/19 07:10 PM
07/30/19 07:10 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Absolutely not good numbers at all. Either they are fake, or someone doesnt know how to calibrate their sonic tester. You first do whats called a " probe zero", then you calibrate it to a known and measurable thickness.
RIP Monte Smith
