Re: Can it be done with the stock fuel tank? [Re: rjones] #268087
03/28/09 08:15 AM
03/28/09 08:15 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
The fuel filter is an inline type between the fuel pressure regulator and carb. It has 3/8 inch connections.
This does not seem right to me. You should minimize restrictions after the regulator. What side of the fuel filter are you measuring your fuel pressure? Does your filter see a lot of engine heat?
Do you have a picture of the under hood stuff, line, regulator, filter, and fuel pressure pick-up location?
I've run a Mallory 110 pump on mine (7.60s to 7.70s) and the pump could not keep up. I know others who run a 110 pump that are faster than me without any problems - the devil is in the details of the entire fuel delivery system and mine is fair at best. However, my problem was not intermittent or weather dependent.
Re: Can it be done with the stock fuel tank? [Re: BSB67] #268088
03/28/09 11:42 AM
03/28/09 11:42 AM
Midland, Tx
rjones Offline OP
rjones  Offline OP
Midland, Tx
Thanks for the tech support on this.
Just did the fuel flow test into 5 gal bucket. Measured the fuel flow on the final connection into the carb. It took 3 minutes and 45 seconds to flow 5 gallons. This comes out to only 45 gph. Please check my math on this to be sure I am correct. This surprised me since the pump is rated at 110 gph. I thought it would do at least 60 gph.
The fuel filter is currently located between the regulator and the carb. I am going to relocate it to between the pump and the regulator and repeat the test. I will report back later this afternoon or evening.
Thanks,
Roger
Re: Can it be done with the stock fuel tank? [Re: rjones] #268089
03/28/09 02:51 PM
03/28/09 02:51 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Try it without the filter too
Re: Can it be done with the stock fuel tank? [Re: rjones] #268090
03/28/09 02:59 PM
03/28/09 02:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks,
Roger
The pump is deigned to flow unrestricted (advertised
flow)
so it will be less with the regulator in line
Re: Can it be done with the stock fuel tank? [Re: MR_P_BODY] #268091
04/01/09 05:16 PM
04/01/09 05:16 PM
Midland, Tx
rjones Offline OP
rjones  Offline OP
Midland, Tx
OK, finally got back to it. I moved the fuel filter from under the hood to the back of the car away from any heat. It is now between the fuel pump and the pressure regulator. Did the fuel flow test again with the 5 gallon bucket and there was no change, still 45 gph. I will drive it a few days and see if problem repeats.
Thanks for the help.
Roger
