convert 70 charger pdb to manual,what do i need?
#2680308
07/23/19 02:12 AM
07/23/19 02:12 AM
Posts: 1,794 BC Canada
ogopogo
BC Canada
Ive been working on my beater 70 v code charger with pdb,planning to put a 426 hemi into it tomorrow and just realized i dont think it will fit with the non hemi power disc booster.easiest solution is to switch the car to manual brakes for now,,,,,,,what do I need for parts to do this??
Re: convert 70 charger pdb to manual,what do i need?
[Re: ogopogo]
#2680369
07/23/19 09:24 AM
07/23/19 09:24 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Ive been working on my beater 70 v code charger with pdb,planning to put a 426 hemi into it tomorrow and just realized i dont think it will fit with the non hemi power disc booster.easiest solution is to switch the car to manual brakes for now,,,,,,,what do I need for parts to do this?? D, You'll need a manual master pedal pushrod, or use the adjustable MP pushrod, the manual master firewall plate, and a manual disc/drum master (assuming you have factory discs?) there is a manual disc/drum master that is a "bolt on" factory style master, I'll assume your master line exits are "outboard", meaning they are between the master and the side firewall?, not between the engine and master?, I'll post the master PN later when I can access my notes Mike
[Re: ogopogo]
#2680759
07/24/19 03:30 AM
07/24/19 03:30 AM
Posts: 18,157 Mass
DAYCLONA
Mass
yes my outlets are outboard and factory disc brake car D, You could use the manual disc/drum master 1627, available from Autozone/CQ, NAPA, Advance, Ebay etc, etc....either 10-1627 or M1627 should yield you a master at any of the parts stores.....personally I prefer Fenco re-manufactured masters M1627 over the Cardone re-manned units 10-1627 Mike
