What Plugs for TF 240 #2680392
07/23/19 10:15 AM
07/23/19 10:15 AM
It's Complicated
HDNMOPERS Offline OP
It's Complicated
Getting ready to fire up the 512 to break in the cam. Whats a good plug to start with for the TF 240s. 512 pump gas 10.3 comp.
Re: What Plugs for TF 240 [Re: HDNMOPERS] #2680404
07/23/19 10:38 AM
07/23/19 10:38 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I'm using Autolite 3924 in my 448 (.040 over 440) that has 10.9:1 compression with TF 240. I'm running a mixture of 2:3 race gas (110) to pump gas (93).
Re: What Plugs for TF 240 [Re: HDNMOPERS] #2680424
07/23/19 11:03 AM
07/23/19 11:03 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
A 7 or 8 heat range NGK should work fine. Street use a 7 and strip the 8.
Re: What Plugs for TF 240 [Re: HDNMOPERS] #2680449
07/23/19 11:56 AM
07/23/19 11:56 AM
AndyF Offline
AndyF  Offline
For a street car on pump gas I'd use NGK 6987. That is a #6 plug with extra extended tip and an extra wide gap. It is an OEM plug used in new cars.
Re: What Plugs for TF 240 [Re: AndyF] #2680464
07/23/19 12:46 PM
07/23/19 12:46 PM
It's Complicated
It's Complicated
Thanks for the replies. I appreciate it.
