World iron block runs warmer
#2679820
07/21/19 05:32 PM
07/21/19 05:32 PM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
Anyone had this ? I have my new World block 505ci in and running . But it does run warmer than my factory 440 and 505 . Maybe 15-20F . Cooling system has never been an issue . I just swapped in a 2nd waterpump to which I welded a anti cavitation plate , I did have a 440 source pump in when I ftted motor . Just the thicker block ? Its not a worry at the moment but noticeable .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
Re: World iron block runs warmer
[Re: tex013]
#2679838
07/21/19 06:53 PM
07/21/19 06:53 PM
Posts: 12,293 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I have a World block. 540", 180* thermostat, OE style radiator, and OE style water pump with clutch fan. Cools just fine. But boy, is it heavy.
If this motor is running 15* to 20* warmer than your old 440 and is not a worry, how cool did your 440 run?
A little more info will get you more input.
Master, again and still
[Re: Dragula]
#2679871
07/21/19 08:21 PM
07/21/19 08:21 PM
Posts: 4,213 New York
polyspheric
New York
Why? Less water circulation? Bad distribution planning? Smaller jacket x-section near the deck? Any chance that it needs a different head gasket (have they changed the gasket since your purchase)? Chevy changed the head-to-block water flow many times between 1937-63 on the L6. If this turns out to be an issue, I'd consider external water to the rear core plugs like Chrysler did to the Cummins.
Boffin Emeritus
[Re: DaveRS23]
#2679873
07/21/19 08:25 PM
07/21/19 08:25 PM
tex013
Sydney,Australia
Dave , I have not run a tstat for years . Old motors ran cooler without plus not keen to get stuck in the lanes with cold motor and closed tstat . As to old temps . Would normally run 155-175 on cool days and running down freeway . Once in middle of winter ran highway for 11 hours never got to over 130 , it was 0 celcius and lower most of that . Yes in traffic would slowly creep up , fans kept it under 210ish even in 40deg C (100F) Now heats up quicker and runs about 185-190 on freeway . We are in winter here now so have not had real hot days yet . Dragula , thanks . If I remember you have similar issues ? I have the Mopar performance 5 blade clutch fan and a 12"manual control pusher fan , factory shroud on cross flow AFCO radiator .
Tex
[Re: FastmOp]
#2679912
07/21/19 10:49 PM
07/21/19 10:49 PM
tex013
Sydney,Australia
thanks Dragula - I was leaning that way but wanted others experience Fastmop , already got it . Always use it . Oh well looks like wait and see . May have to go to Aus Falcon factory twin fan set up , I know they always work
Tex
[Re: tex013]
#2679923
07/21/19 11:05 PM
07/21/19 11:05 PM
Posts: 12,418 Taxes & Virus's R-US, NY
Dragula
Well, I have had 9 engines in my car over the years, and this latest World Iron block is tough to keep cool...I have a very good cooling system.....Yet it seems on a hot day, I can't keep it from getting to 215....I have the engine out right now to put new valve springs in it, and its for sale, but if it goes back in, I am going to put in a newer style 4000cfm fans...I am right on the edge. It will cool down on a long cruise, but not in traffic once it hits 200....
[Re: Dragula]
#2679942
07/22/19 12:39 AM
07/22/19 12:39 AM
tex013
Sydney,Australia
Topside , fan never been an issue before . I don't run antifreeze , definitely no freezing here ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) Dragula , [img] https://www.autopartssupply.com.au/ford-au-falcon-radiator-thermo-fan-twin-fans-suit[/img] Now days I try to use OE styled fans because they are designed better and have to last a long warranty . Tex
[Re: tex013]
#2679962
07/22/19 01:48 AM
07/22/19 01:48 AM
Posts: 81 Sweden
MikeN
Sweden
[Re: dart games]
#2679968
07/22/19 03:09 AM
07/22/19 03:09 AM
tex013
Sydney,Australia
69b1 , purely 98 pump gas Will not go E fuel Mike , those both seem to be hemi specific . I have a wedge Doesnt go mad , just warmer Thanks to everyone ,
Tex
[Re: tex013]
#2680034
07/22/19 10:18 AM
07/22/19 10:18 AM
Dragula
Yeah its just a slow warm up, but once it gets there, its really tough to bring it back down. Takes mine a good 45 minutes or more of driving before it gets there, but its a lot of iron to cool down....once it is. I do run either water wetter or Antifreeze depending on the time of year. And if its cool outside, its not an issue...So I am right on the edge with my setup. Any improvement should show up immediately.
At the drags, Its actually difficult to get it to full temp. I actually only use one fan to save on battery power, and it never gets past 180....
[Re: Dragula]
#2680188
07/22/19 05:47 PM
07/22/19 05:47 PM
tex013
Sydney,Australia
thanks Dragula . will see how it goes into spring/summer . Maybe I should have gone 4.41 or 4.5 bore to thin it down ![eek eek](/ubbthreads/images/graemlins/custom/eek.gif) Tex
[Re: tex013]
#2680381
07/23/19 09:58 AM
07/23/19 09:58 AM
Posts: 17,914 S.E. Michigan
ZIPPY
S.E. Michigan
Tex or anyone,
Any noticeable change in oil temperature (if it is being monitored)?
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2680614
07/23/19 05:38 PM
07/23/19 05:38 PM
tex013
Sydney,Australia
[quote=ZIPPY]Tex or anyone,
Zippy , I do not run a oil temp gauge . I only monitor it off oil pressure , as motor warms up . Does not seem more than 5 psi variation hot or cold , idle and above 3500 . Between these it is down a little but still running 40psi . But that may be the constant top end oiling , even with the World restrictors fitted . And I swapped mechanical gauges , and used braided -4 line , just before fitting the World . Old 440 IIRC read similar . I do run the large Milodon road/race pan . Currently Brad Penn 20/50 , will go to Royal Purple 20/50 in a couple of months . That is what I ran in the old motors .
Tex
