Re: Earlier 340 Internals in 1973 318's [Re: Sixpak] #2680653
07/23/19 07:35 PM
07/23/19 07:35 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
his source is right, 273, 318 and 340 had bronze bushed floating pistons till around 73
Re: Earlier 340 Internals in 1973 318's [Re: HotRodDave] #2680663
07/23/19 08:14 PM
07/23/19 08:14 PM
P
Porter67 Offline
Porter67  Offline
P
Come on guys this is simple basic mopar stuff. And its easily found on the web as well.
Keep in mind if you ever build with a cast 3.31 crank and lighter rods grab a early 318 crank that used the thin rods. Although the weight difference isnt as much as on would think or by the way they look side by side the early vs later rods.
But here is a basic bushed 273/ early 318 rod.
Moparts really blows on real world normal guy tech, im not a member of fabo but anytime I need to find good solid usable info, the search engines almost always point to fabo.
https://www.forabodiesonly.com/mopar/threads/273-318-connecting-rod-weights.380169/
Re: Earlier 340 Internals in 1973 318's [Re: Porter67] #2680696
07/23/19 09:28 PM
07/23/19 09:28 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
As I remember, the 273 and 318 rods had the bronze bushings, but the pins were pressed into the pistons, the 340 piston pins were floating in the 340 pistons and in the rods. The 340 piston pins were held in place with the lock clips.
The pressed pins in the pistons on the 318 and 273 is what is confusing most of the guys. You had to have the pins pressed out on the 318s and 273s. Gene
Re: Earlier 340 Internals in 1973 318's [Re: poorboy] #2680704
07/23/19 09:48 PM
07/23/19 09:48 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I have torn down a bunch of 318's in my youth. I never saw one with floating pins.
Re: Earlier 340 Internals in 1973 318's [Re: slantzilla] #2680716
07/23/19 10:16 PM
07/23/19 10:16 PM
P
Porter67 Offline
Porter67  Offline
P
Go find some untouched early 318s and learn.
One piston is a 69 here the other is a 70.
Re: Earlier 340 Internals in 1973 318's [Re: poorboy] #2680717
07/23/19 10:25 PM
07/23/19 10:25 PM
P
Porter67 Offline
Porter67  Offline
P
but the pins were pressed into the pistons................. HUH?
Thats crazy talk..... yea pressed in by hand them insert clip. I guess my three fingers are a human press.
Re: Earlier 340 Internals in 1973 318's [Re: Porter67] #2680719
07/23/19 10:29 PM
07/23/19 10:29 PM
P
Porter67 Offline
Porter67  Offline
P
Hello, it was all just like the 340 floating setup. Look at the pics I posted.
Just like a 340 the early ones ALL slid together and were held in by clips.
Re: Earlier 340 Internals in 1973 318's [Re: Porter67] #2680724
07/23/19 10:39 PM
07/23/19 10:39 PM
P
Porter67 Offline
Porter67  Offline
P
Here, look at the factory part numbers, chase some down and DONT for your retainer clips.
Re: Earlier 340 Internals in 1973 318's [Re: Porter67] #2680925
07/24/19 02:29 PM
07/24/19 02:29 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
It's because they made it such a pain in the butt to post pics and such, I know I post a lot less stuff now because of it.
