Wedge Motor 4500 Intake porting Q: New Best
#2679122
07/19/19 03:09 PM
07/19/19 03:09 PM
Posts: 12,420 Taxes & Virus's R-US, NY
Dragula
So I have a 400/512....The 4500 intake has a clover leaf machined into it......Should I knock all that material out of there so the edges are straight from corner to corner or leave it and look for more power elsewhere?
My gut says to knock all that out of there....
Re: Wedge Motor 4500 Intake porting Q"
[Re: mopar dave]
#2679140
07/19/19 03:55 PM
07/19/19 03:55 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Wilsons suggested I knock all that out of there, so I did. I’m not sure why guys thin the carb gasket sealing area down to almost nothing like in that picture.
[Re: pittsburghracer]
#2679143
07/19/19 04:01 PM
07/19/19 04:01 PM
Dragula
So it sounds like at a minimum take it all out to the gasket and blend from there......I was thinking that...Motor seems like it wants more plenum, but I do not have any more room for taller spacers. So I have to ask, did you run it down the track yet, and did that work?
[Re: Dragula]
#2679191
07/19/19 07:05 PM
07/19/19 07:05 PM
Dragula
Ok....So I only have a little more to go on the top flange plenum area.......Any tricks for the runners?
My carb guy thinks the remaining HP is in the intake, so I figured I would give it some attention....If anything, it will be lighter. I would really like to see the car get down in the 6.0's....
[Re: mopar dave]
#2679193
07/19/19 07:09 PM
07/19/19 07:09 PM
Posts: 326 Alberta
Wookie316
Alberta
Here is my personal experience with the Indy cloverleaf. When I still had it. Car ET’d and MPH’d better with carb right on the manifold. I removed it but never actually got a chance to test that way other than the dyno. On the dyno the fuel numbers were all over the map with it removed. Now was this because of the manifold or the other heads and cam I had on the motor? That I am not sure of. Before I did any actual track time I sent the manifold to Wilson for a full competition port. Never dyno’d the motor again but here are this years results. Before cutting cloverleaf out, running carb direct to manifold with a heavily ported EZ-1 that had 2.25 intake valves, the car ran 10.12 @ 133 and change with a 1.42 60. That was a 4.30 gear. This year the combo is the same except I have 4.10 gears and mild ported EZ-1 with a 2.19 intake valve. The Ported Wilson Manifold has a 1” taper spacer and the same carb as before. Car ran a best of 10.10 @ 132 and change with a 1.38 60. Now is the manifold Work offsetting the smaller head? Is the 4.10 a better combo for my low gear set in the 727? Is it a little of everything? Probably. With the wild fuel numbers I got on the dyno, I am not sure I would remove it without doing other work to it? Simply squaring it off I think is a step backwards. A proper blend is needed too. Talk to Wilson. It is expensive but so far I find it was money well spent.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
[Re: Dragula]
#2679557
07/20/19 08:55 PM
07/20/19 08:55 PM
BradH
So my new open 1" spacer showed up today.....The intake is all done and back on the car, so now the spacer debate begins....Going to start with a 1" big open one.....I still have the clover leaf one, and a tapered 1" aluminum one.....What's the hot ticket? Ummmm... the one that works best with your combination.
[Re: BradH]
#2679559
07/20/19 08:58 PM
07/20/19 08:58 PM
Dragula
So my new open 1" spacer showed up today.....The intake is all done and back on the car, so now the spacer debate begins....Going to start with a 1" big open one.....I still have the clover leaf one, and a tapered 1" aluminum one.....What's the hot ticket? Ummmm... the one that works best with your combination. You guys are too smart for me....lol
[Re: Dragula]
#2679567
07/20/19 09:08 PM
07/20/19 09:08 PM
BradH
So my new open 1" spacer showed up today.....The intake is all done and back on the car, so now the spacer debate begins....Going to start with a 1" big open one.....I still have the clover leaf one, and a tapered 1" aluminum one.....What's the hot ticket? Ummmm... the one that works best with your combination. You guys are too smart for me....lol I could have just said: "It depends..." ![tonguue tonguue](/ubbthreads/images/graemlins/custom/tonguue.gif)
[Re: BradH]
#2679706
07/21/19 11:33 AM
07/21/19 11:33 AM
fast68plymouth
So. Burlington, Vt.
Here....... let me help you out with that.......
“It depends”
[Re: fast68plymouth]
#2681908
07/27/19 09:58 PM
07/27/19 09:58 PM
Dragula
Well, the verdict is in......New bests with my 400/512 combo
I picked up almost .05 this week in the heat.......So back to back testing from last week to this week with the only change the porting....
So last week the car went 6.24 on the 1st pass.....Today in the heat, it went 6.18 on opening pass. After that, the tires got better and so did my next two passes....Went a new best 6.13 at 111.89mph with a 1.341 60ft......So it begs the question, how much more can I port the intake?
I made no jetting changes and in the 93 degree heat I did not check the plugs....It was just too hot.
[Re: Dragula]
#2681920
07/27/19 11:28 PM
07/27/19 11:28 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
What was the corrected altitude and humidity on those weeks.
