Re: Dual Plane Intake Porting Pics
[Re: parksr5]
#2679779
07/21/19 03:07 PM
07/21/19 03:07 PM
Posts: 4,206 New York
polyspheric
New York
I think we all understand that a 180° dual plane manifold cannot be made to flow as evenly across all of the ports as a single plane, that in addition to A > B comparisons there might be a significant different between the 4 fed by the left side of the carburetor and its plenum, and the 4 fed by the other, and that the highest flow to the best cylinder won't be comparable? I have more detail on this on my page here (I also ran this in "MoPar Action"): http://victorylibrary.com/mopar/intake-tech-c.htm#dpI'm curious about something else: the actual cylinder pressure. If the weakest cylinder has lower % VE, this means it will not be as "full" of mixture (same volume, lower mass) when the intake valve closes. The actual output of that cylinder will be lower. The question: are any stock manifolds so bad that this may be a problem? It might show up as a colder plug in a weak cylinder.
Boffin Emeritus
[Re: parksr5]
#2681004
07/24/19 06:22 PM
07/24/19 06:22 PM
Posts: 55 CT
roadrunner2
CT
[img] https://flic.kr/p/2gG9seA[/img] [img] https://flic.kr/p/2gG9sio[/img] [img] https://flic.kr/p/2gG9siU[/img] Working on right now. Still a few days from completion but gives a good idea where it’s heading. This is for a 383 vid motor with under 10:1 compression. Bill
1968 Road Runner 383 727 3.91 8 3/4 3520 with driver 11.04 @ 124.26 with 1.67 60’ Done on G70-14 redlines thru factory manifolds New quickest ever 383 build in FAST. 10:1 451” replaced with 14:1 499”.
[Re: roadrunner2]
#2681011
07/24/19 06:46 PM
07/24/19 06:46 PM
Posts: 14,496 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Any other mods to that 383 to go along with the intake?
[Re: fast68plymouth]
#2681012
07/24/19 06:53 PM
07/24/19 06:53 PM
Posts: 55 CT
roadrunner2
CT
This belongs to the maroon 68 RR. I think he’s getting serious on a build. He got his trans done at Atwoods and had them put 4.10’s in. It’s a start. Having done a few of these now I’m seeing some things I’d like to try out for my intake over the winter. Also, I’ll be contacting you about a roller cam too. 👍🏽
Bill
[Re: roadrunner2]
#2681019
07/24/19 07:45 PM
07/24/19 07:45 PM
fast68plymouth
So. Burlington, Vt.
I like that little lip you leave at the upper/lower plenum transition.
I don’t know if it helps or not, but I like the idea of it.
#2681059
07/24/19 10:54 PM
07/24/19 10:54 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Could you run a 400 intake that had a TQ on it? Plenum might be much bigger
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#2681096
07/25/19 05:11 AM
07/25/19 05:11 AM
Posts: 55 CT
roadrunner2
CT
Intake has to be correct for the car it’s in. 68/69 383’s use the 301 intake.
Bill
#2681101
07/25/19 06:23 AM
07/25/19 06:23 AM
Posts: 55 CT
roadrunner2
CT
I don’t know if it helps or not, but I like the idea of it. Do you find that the upper or lower plane gets more flow? More work on the more restrictive plane would be needed. Bill
[Re: parksr5]
#2681164
07/25/19 09:56 AM
07/25/19 09:56 AM
Posts: 2,094 central texas
krautrock
central texas
You’re probably already aware of it, but there’s a guy running in Supercar with a 451 in a 68RR....... and I don’t think he’s dipped into the 11’s yet..... but he’s knocking on the door(with legal tires). I think he’ll probably get it this fall. He does a lot of his own work too. I think he had some pics of his manifold posted somewhere. Nice work on the garage I believe I saw some pics and posts from that guy on FBBO. I'll have to look around to see if I can find any of his intake manifold pics. Thanks for the kind words about the garage! if you find a link to the guys 451 build can you post a link? like you, i'm working on finishing up a garage...then planning to get to work on my slightly ratty 67 coronet. Not looking to do a FAST build but probably 70's street racer style (to an extent), might build a 451 for it so i'm always looking at those builds.
[Re: roadrunner2]
#2681167
07/25/19 10:04 AM
07/25/19 10:04 AM
fast68plymouth
So. Burlington, Vt.
Basically, the 4 runners that have the sharpest turn coming out of the plenum flow the least...... the “inner” runners. 3,5,4,6. I’d have to dig out my notes since I did that testing quite a while ago, but that’s how I remember it. Not really much difference between upper and lower. That’s tested as bolted to a ported head, and comparing how much flow is lost with the manifold in place(and it loses a bunch). The overall best one I’ve tested was extensively modified by Jim Sieler for his Dart. His motor was a very high effort build with several pretty high dollar parts in it....... and it made quite good power on the dyno. He never quite got the car sorted out well enough to use all the power he had. I’m sure if he would have stuck with it, there would have been some very low 11-sec ET’s...... and maybe even a “10” at MIR on a killer day. He’s also a fun guy to have around at the track....... wish he was still playing in those classes. if you find a link to the guys 451 build can you post a link? It’s roadrunner2’s motor, in his car. Edit: this is why it’s best not to go by memory....... On a mildly reworked 301, all the ports lost about 20-21% compared to the head by itself(about 50cfm). It looks like the % of loss is within about 1% for all runners, on one that has what I would consider a “normal” amount of rework. At that level of rework, on a head that flows solidly over 280cfm, its about an 18cfm improvement avg for all 8 runners over the untouched manifold. Jim’s intake averaged 13cfm better than the one with the “normal” rework, although some of his ports flowed over 30cfm better than the same runner on the one with normal porting. What brought the average down was there were two runners that showed minimal improvement at all over the stock intake. Runners #1 and #7. To put it in perspective, the 8cyl flow average for the head with a radius plate was 286.7cfm. The intake was tested bolted to the head with all ports blocked off except the one being tested, and a Holley 1000cfm 4150 carb mounted to the carb pad. The 8cyl flow average for the stock manifold was 212.8cfm. The 8cyl flow average for the normally ported manifold was 230.7cfm. The 8cyl flow average for an ootb Performer RPM was 250.6cfm. If Jim could have picked up #1 and #7 about 15cfm..... the 8cyl flow average would have been right there with the RPM. Some of the runners on a cleaned up Victor only lost a few cfm compared to the head with the radius plate.
[Re: krautrock]
#2681347
07/25/19 05:30 PM
07/25/19 05:30 PM
Posts: 55 CT
roadrunner2
CT
You’re probably already aware of it, but there’s a guy running in Supercar with a 451 in a 68RR....... and I don’t think he’s dipped into the 11’s yet..... but he’s knocking on the door(with legal tires). I think he’ll probably get it this fall. He does a lot of his own work too. I think he had some pics of his manifold posted somewhere. Nice work on the garage I believe I saw some pics and posts from that guy on FBBO. I'll have to look around to see if I can find any of his intake manifold pics. Thanks for the kind words about the garage! if you find a link to the guys 451 build can you post a link? like you, i'm working on finishing up a garage...then planning to get to work on my slightly ratty 67 coronet. Not looking to do a FAST build but probably 70's street racer style (to an extent), might build a 451 for it so i'm always looking at those builds. That guy is me.
#2681440
07/25/19 11:12 PM
07/25/19 11:12 PM
Posts: 4,313 Prospect, PA
BSB67
Prospect, PA
Basically, the 4 runners that have the sharpest turn coming out of the plenum flow the least...... the “inner” runners. 3,5,4,6. I’d have to dig out my notes since I did that testing quite a while ago, but that’s how I remember it. Not really much difference between upper and lower. That’s tested as bolted to a ported head, and comparing how much flow is lost with the manifold in place(and it loses a bunch). The overall best one I’ve tested was extensively modified by Jim Sieler for his Dart. His motor was a very high effort build with several pretty high dollar parts in it....... and it made quite good power on the dyno. He never quite got the car sorted out well enough to use all the power he had. I’m sure if he would have stuck with it, there would have been some very low 11-sec ET’s...... and maybe even a “10” at MIR on a killer day. He’s also a fun guy to have around at the track....... wish he was still playing in those classes. if you find a link to the guys 451 build can you post a link? It’s roadrunner2’s motor, in his car. Edit: this is why it’s best not to go by memory....... On a mildly reworked 301, all the ports lost about 20-21% compared to the head by itself(about 50cfm). It looks like the % of loss is within about 1% for all runners, on one that has what I would consider a “normal” amount of rework. At that level of rework, on a head that flows solidly over 280cfm, its about an 18cfm improvement avg for all 8 runners over the untouched manifold. Jim’s intake averaged 13cfm better than the one with the “normal” rework, although some of his ports flowed over 30cfm better than the same runner on the one with normal porting. What brought the average down was there were two runners that showed minimal improvement at all over the stock intake. Runners #1 and #7. To put it in perspective, the 8cyl flow average for the head with a radius plate was 286.7cfm. The intake was tested bolted to the head with all ports blocked off except the one being tested, and a Holley 1000cfm 4150 carb mounted to the carb pad. The 8cyl flow average for the stock manifold was 212.8cfm. The 8cyl flow average for the normally ported manifold was 230.7cfm. The 8cyl flow average for an ootb Performer RPM was 250.6cfm. If Jim could have picked up #1 and #7 about 15cfm..... the 8cyl flow average would have been right there with the RPM. Some of the runners on a cleaned up Victor only lost a few cfm compared to the head with the radius plate. Thanks. Would not have guessed it.
#2681477
07/26/19 05:58 AM
07/26/19 05:58 AM
Posts: 55 CT
roadrunner2
CT
Basically, the 4 runners that have the sharpest turn coming out of the plenum flow the least...... the “inner” runners. 3,5,4,6. I’d have to dig out my notes since I did that testing quite a while ago, but that’s how I remember it. Not really much difference between upper and lower. That’s tested as bolted to a ported head, and comparing how much flow is lost with the manifold in place(and it loses a bunch). The overall best one I’ve tested was extensively modified by Jim Sieler for his Dart. His motor was a very high effort build with several pretty high dollar parts in it....... and it made quite good power on the dyno. He never quite got the car sorted out well enough to use all the power he had. I’m sure if he would have stuck with it, there would have been some very low 11-sec ET’s...... and maybe even a “10” at MIR on a killer day. He’s also a fun guy to have around at the track....... wish he was still playing in those classes. if you find a link to the guys 451 build can you post a link? It’s roadrunner2’s motor, in his car. Edit: this is why it’s best not to go by memory....... On a mildly reworked 301, all the ports lost about 20-21% compared to the head by itself(about 50cfm). It looks like the % of loss is within about 1% for all runners, on one that has what I would consider a “normal” amount of rework. At that level of rework, on a head that flows solidly over 280cfm, its about an 18cfm improvement avg for all 8 runners over the untouched manifold. Jim’s intake averaged 13cfm better than the one with the “normal” rework, although some of his ports flowed over 30cfm better than the same runner on the one with normal porting. What brought the average down was there were two runners that showed minimal improvement at all over the stock intake. Runners #1 and #7. To put it in perspective, the 8cyl flow average for the head with a radius plate was 286.7cfm. The intake was tested bolted to the head with all ports blocked off except the one being tested, and a Holley 1000cfm 4150 carb mounted to the carb pad. The 8cyl flow average for the stock manifold was 212.8cfm. The 8cyl flow average for the normally ported manifold was 230.7cfm. The 8cyl flow average for an ootb Performer RPM was 250.6cfm. If Jim could have picked up #1 and #7 about 15cfm..... the 8cyl flow average would have been right there with the RPM. Some of the runners on a cleaned up Victor only lost a few cfm compared to the head with the radius plate. That’s exactly the info I wanted, thanks D. Bill
[Re: roadrunner2]
#2681515
07/26/19 09:58 AM
07/26/19 09:58 AM
fast68plymouth
So. Burlington, Vt.
I don’t really like porting intake manifolds, so I don’t do much of it.
One thing I found interesting when testing manifolds is that they “usually” result in some amount of loss in flow from the head, when attached....... even when they are capable of flowing way more than the head they’re attached to.
Years ago I was messing with some std port Indy SR heads. I got them to flow in the 340 range, and was testing some manifolds on them. An M1 single plane with very minimal plenum deburring and a gasket match would flow a little over 300cfm when attached to the head. Or rather, the head would flow a little over 300 with the manifold attached.
So, we know the intake is good for over 300....... and yet when you bolt it to an unported 906 head that only flows in the 230’s...... the head still loses flow.
On those 286cfm 906’s in my previous post, that same M1 intake that was passing 300+ cfm when on the SR’s, knocked the 8cyl avg down to 263cfm.
#2681571
07/26/19 12:04 PM
07/26/19 12:04 PM
Posts: 55 CT
roadrunner2
CT
On those 286cfm 906’s in my previous post, that same M1 intake that was passing 300+ cfm when on the SR’s, knocked the 8cyl avg down to 263cfm. I enjoy doing intakes. I’ll probably have a collection of different one that all performed exactly the same, tho not for lack of trying. My guess, uneducated, is the longer combined runners carry more volume with more weight and inertia. Combined with adding turns and more drag along a longer surface. 🤔 Bill
[Re: roadrunner2]
#2681579
07/26/19 12:25 PM
07/26/19 12:25 PM
Posts: 20,172 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I call intake porting my no brainer work and will grab one on an evening I’m into listening to some good music and sipping on an adult beverage. I know want I want to aim for so I lay it all out with blueing and go to town. I usually have a small or big block head with known flow numbers mounted on my flowbench so set up time is reduced.
[Re: pittsburghracer]
#2681606
07/26/19 02:39 PM
07/26/19 02:39 PM
fast68plymouth
So. Burlington, Vt.
I’m happy to let you guys get aaaaaaaallll the manifold porting........ especially the stock iron ones.
My suspicion is that most of what’s been done with these 301 intakes would end up making similar power(with the exception of the JS piece). Unless you happen to come up with something substantially better, I think it might be pretty hard to quantify the differences when the measuring tool is a 3500lb car running on tires with limited traction....... in different weather conditions....... at different tracks. And let’s not forget the restrictive exhaust manifolds added to the mix.
Some little tweak that could be worth 3-5hp just gets lost in all the variables.
#2681651
07/26/19 05:59 PM
07/26/19 05:59 PM
sixpackgut
Charleston
Basically, the 4 runners that have the sharpest turn coming out of the plenum flow the least...... the “inner” runners. 3,5,4,6. I’d have to dig out my notes since I did that testing quite a while ago, but that’s how I remember it. Not really much difference between upper and lower. That’s tested as bolted to a ported head, and comparing how much flow is lost with the manifold in place(and it loses a bunch). The overall best one I’ve tested was extensively modified by Jim Sieler for his Dart. His motor was a very high effort build with several pretty high dollar parts in it....... and it made quite good power on the dyno. He never quite got the car sorted out well enough to use all the power he had. I’m sure if he would have stuck with it, there would have been some very low 11-sec ET’s...... and maybe even a “10” at MIR on a killer day. He’s also a fun guy to have around at the track....... wish he was still playing in those classes. if you find a link to the guys 451 build can you post a link? It’s roadrunner2’s motor, in his car. Edit: this is why it’s best not to go by memory....... On a mildly reworked 301, all the ports lost about 20-21% compared to the head by itself(about 50cfm). It looks like the % of loss is within about 1% for all runners, on one that has what I would consider a “normal” amount of rework. At that level of rework, on a head that flows solidly over 280cfm, its about an 18cfm improvement avg for all 8 runners over the untouched manifold. Jim’s intake averaged 13cfm better than the one with the “normal” rework, although some of his ports flowed over 30cfm better than the same runner on the one with normal porting. What brought the average down was there were two runners that showed minimal improvement at all over the stock intake. Runners #1 and #7. To put it in perspective, the 8cyl flow average for the head with a radius plate was 286.7cfm. The intake was tested bolted to the head with all ports blocked off except the one being tested, and a Holley 1000cfm 4150 carb mounted to the carb pad. The 8cyl flow average for the stock manifold was 212.8cfm. The 8cyl flow average for the normally ported manifold was 230.7cfm. The 8cyl flow average for an ootb Performer RPM was 250.6cfm. If Jim could have picked up #1 and #7 about 15cfm..... the 8cyl flow average would have been right there with the RPM. Some of the runners on a cleaned up Victor only lost a few cfm compared to the head with the radius plate. That was awesome
