What Do YOU Want Howards Cams To Make For Mopars?
#267858
03/27/09 12:37 AM
03/27/09 12:37 AM
Posts: 85 Wellington, Ohio (20 minutes f...
MrMoparRacing
Howards Cams currently makes these items for Small Block Mopar: Hydraulic Flat Tappet Camshafts Mechanical Flat Tappet Camshafts Steel Billet Mechanical Roller Camshafts Billet Timing Sets Cam Correct Hydraulic Lifters Mechanical Lifters “THE ORIGINAL” Direct Lube Solid Lifters Mechanical Racing Roller Lifters (Vertical Bar) Race Valve Springs, Retainers, Locks, Seals, Caps Distributor Gears Ultimate Duty Billet Connecting Rods
Big Block Mopar: Hydraulic Flat Tappet Camshafts Mechanical Flat Tappet Camshafts (3 Bolt) Steel Billet Mechanical Roller Camshafts (3 Bolt) Billet Timing Sets (singe & three bolt) Cam Correct Hydraulic Lifters Mechanical Lifters “THE ORIGINAL” Direct Lube Solid Lifters Mechanical Racing Roller Lifters (Vertical Bar) Race Valve Springs, Retainers, Locks, Seals, Caps Distributor Gears
Howards Cams is wanting to know what MOPAR customers want Howards Cams to make that they currently do not offer. Rocker arms, crankshafts, connecting rods, pushrods, stroker pistons ect. Please be specific to exact sizes, such as rod length, stroke, piston bore, ect. Your input is highly valued!
Howards Cams products are MADE IN THE USA!
Howards Cams products are now available at Summit Racing Equipment!
Re: What Do YOU Want Howards Cams To Make For Mopars?
[Re: MrMoparRacing]
#267862
03/27/09 01:50 AM
03/27/09 01:50 AM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
An affordable quality H-beam rod and 440 6pak style flat top pistons for 440 Mopar.The rods should be stock size(.990 pin OK)6.76 length,3.75 stroke,pistons in +.020,.030.040 and .060 oversizes from 4.320 standard bore.
[Re: Chris2581]
#267863
03/27/09 02:04 AM
03/27/09 02:04 AM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
Same with a 383. Lots of guys still building those. Just look in the Q&A every now and then.
[Re: S/ST 3040]
#267868
03/27/09 08:03 AM
03/27/09 08:03 AM
Posts: 210 mass,usa
sickhemi
mass,usa
W2 rockers affordable ![](/ubbthreads/images/graemlins/biggrin.gif)
1968 gts 355 r3 six speed efi with irs in progress and 1969 convt 440 stage 6 efi 5spd dana
[Re: sickhemi]
#267870
03/27/09 08:45 AM
03/27/09 08:45 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
I'd love a 4" strock SBM USA forged/USA machined crank in the same price range as their USA forged/USA machined SBC cranks, maybe a cast crank option in the $400 range if it was cast/machined in the USA.
I'd really, really love them to make their powderforged rods in SBM size, or at least 6.125" SBC, with the little end designed such that they could have a SBM pin size option without having to do a lot of spendy rework. those powderforged rods look like they'd be awesome for a street build up, or any application where you're looking at under 600HP or so.
[Re: patrick]
#267871
03/27/09 09:25 AM
03/27/09 09:25 AM
Posts: 1,943 San Angelo, Texas, U.S.A.
1968RR
I just installed my new Howard's cam earlier this week (haven't fired yet). Y'all have great customer service and great products. Keep up the good work. ![](/ubbthreads/images/graemlins/thumbs.gif)
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
[Re: 1968RR]
#267872
03/27/09 10:51 AM
03/27/09 10:51 AM
Posts: 1,572 wisconSIN
Blown61
wisconSIN
[Re: 1968RR]
#267873
03/27/09 11:24 AM
03/27/09 11:24 AM
Posts: 5,080 organ
maximum entropy
organ
rocker arms! offset for indy, victor, et cetera.
[Re: MrMoparRacing]
#267875
03/27/09 06:08 PM
03/27/09 06:08 PM
Posts: 3,619 Norwich CT USA
Defbob
Norwich CT USA
Big BlockForged Cranks: 4.25", 4.375, 4.5", 4.75" strokes, 2.2" x 2.009" wide rod journal on all, 2.75" mains, 8 bolt Forged Crank: 3.375" stroke, 2.375" X 2.050 wide rod journal, 2.75" mains, 8 bolt Billet Rods: 6.76" long, 2.375 journal, 1.014" width, .990 pin Billet rods: 6.86" long, 2.375 journal, 1.014" width, .990 pin ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: sbdemon]
#267877
03/27/09 07:08 PM
03/27/09 07:08 PM
Posts: 3,695 nc
emarine01
nc
W2/W5 rockers 1.6 1.7 ratio.
sbdemon
![](/ubbthreads/images/graemlins/iagree.gif) ![](/ubbthreads/images/graemlins/grin.gif)
