Re: Trailer tire advice
[Re: Racer68]
#2678738
07/18/19 04:21 PM
07/18/19 04:21 PM
Posts: 4,689 On the parachute mount
n20mstr
Make sure they are always inflated to the correct psi (check psi at every fuel stop)
keep it 65mph or lower
change them out every 3-4 years (sitting in the sun is what kills them)
....BAD A$$ STREET CAR.....
[Re: MR_P_BODY]
#2678752
07/18/19 04:56 PM
07/18/19 04:56 PM
Posts: 632 Casco, MI
Savoy1964
Casco, MI
I am using Goodyear Endurance they are E rated and so far have been a great tire.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph 2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
[Re: Blucuda413]
#2678768
07/18/19 05:29 PM
07/18/19 05:29 PM
Posts: 43,237 Bend,OR USA
Cab_Burge
All good comments by those in the know I hate trailer tires OP, what size tires and rim size and lug nut count are you using? What is the GVW rating on your trailer? I've blown up and had so many trailer tires go bad I've lost count, I now figure on replacing mine every four years regardless of how many mile are on them. I replaced all of mine last year with a set of 225-75-15R E Maxxis brand rated for 2830 Lbs. each at 80 lbs. pressure , which are now made in China. I run 85 Lbs cold in all my E rated trailer tires if they recommend 80 Lbs. cold, I do this due to a Tire Cooper store owners advice to me years ago on how to get the best wear and life span out of any tire regardless of size and application. It has work well for me That is other than on these stupid 15 inch trailer tires I have check on every 15 inch tires I could look up including LT (light truck)tires, none of them have as good, high, as a load rating as the 225-75-15 ST tires due I would put 16 inch rims and tires on my trailer now but they won't fit Good luck on your trip
[Re: Cab_Burge]
#2678771
07/18/19 05:33 PM
07/18/19 05:33 PM
Posts: 2,921 Calgary, Alberta Canada
a12rag
Along with PLYs and LOAD range, check the sidewall for "SPEED" rating . . not rating sidewall, then it's max 60mph. They have ratings I believe, at 60mph, then 65mph, 70 and 81mph . . . note that I am towing at 75 or 80mph but having the "cushion" of maximum ratings, feels better than running 60mph on a 60mph rated tire.
[Re: dvw]
#2678821
07/18/19 07:14 PM
07/18/19 07:14 PM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I had Carlisle 10 ply on my overloaded 24 foot enclosed trailer with 5-10 pounds over what was listed on the sidewalls and had lots of luck with them. My new 26 foot trailer is now rated just under 10,000 pounds and has 16 inch tires on it.
[Re: pittsburghracer]
#2678886
07/18/19 10:07 PM
07/18/19 10:07 PM
Posts: 2,050 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
My last trailer (32" tag, 3 axle) had 15" tires and I ran Carlisles (load range E) with great success. A fellow racer around here has a tire program that just makes since to me. Every year he replaces two tires, before they go bad, that way the tires are never older than two years old (Three axle 48' GN/LQ). One pair new, one pair one year old and one pair two years old. He travels to a few far away races every year (350-500 miles) and a lot of local (75-100 miles). The pair of tires he pulls off goes to spares and the old spares he gives to local racer friends. Since he has gone to this he has had zero tire problems on the road. I agree 100% with those who say the sun is the main killer of tires, not speed or heat. And Always check the air pressure before every trip.
Brian
[Re: dvw]
#2678898
07/18/19 10:26 PM
07/18/19 10:26 PM
Posts: 580 Livermore, CA
Dduster
Livermore, CA
Buy a Tire pressure monitor system for the trailer tires and keep an eye on things as You roll down the road.
[Re: FurryStump]
#2679174
07/19/19 05:45 PM
07/19/19 05:45 PM
Posts: 422 montana
BANDIT
montana
I run a tire called “Westlake”, overseas I’m sure. 10 ply at 80 lbs cold. Dealer hear sells them to me for about $80.00 each. It’s 300 hundred miles one way to my local track, 10 times a year, with the occasional trip to Vegas or Arizona every year. I have went 3 summers on a set of these tires, compared to Carlyles and Goodyear’s junk, which I was lucky to get one season out of. I do cover them when parked and stores trailer in an unheated building during the winter. Jim
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.35@165. 4400 DA 250” Neil and Parks Slip Joint. 7.36@183. 4600 DA 242" Mullis Dragster. 6.90@ 200mph
[Re: BANDIT]
#2679176
07/19/19 05:50 PM
07/19/19 05:50 PM
Posts: 13,603 md
mopars4ever
md
I have Duro on my car trailer and them seem to be ok tires. Not sure if they are China made or not. I have Westlakes on my camper but I don`t use the camper that much. I just changed them due to rot and they were about 5 years old. The sun and running them underinflated seems to kill them prematurely.
[Re: dvw]
#2679285
07/19/19 11:56 PM
07/19/19 11:56 PM
Posts: 16,504 On the run…
BloFish
On the run…
I’ve had Carlisle tires on my two axel Texas Rollback trailer for 10 years now, not a single issue. Trailer sits covered from the sun 24/7. Perhaps I’m due for a new set...
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: BloFish]
#2679289
07/20/19 12:02 AM
07/20/19 12:02 AM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I’ve had Carlisle tires on my two axel Texas Rollback trailer for 10 years now, not a single issue. Trailer sits covered from the sun 24/7. Perhaps I’m due for a new set... I’m guessing he didn’t have the better 10 ply ones or ran then under inflated
