Page 3 of 3 1 2 3
Re: Flat washers under flywheel bolts? [Re: 360view] #3048280
06/06/22 01:01 PM
06/06/22 01:01 PM
moparx Offline
moparx  Offline
i'm almost betting the cut marks allow the bolt head to deform somewhat, affecting the clamping force.
just guessing this, as it seems this type of bolt head is only found in certain applications.
if it were just cosmetic, why take the time to add this feature ?
just my observation over the years.
i have no degree in anything, just [mostly] self taught skills from the school of hard knocks.
beer
Re: Flat washers under flywheel bolts? [Re: moparx] #3048309
06/06/22 01:51 PM
06/06/22 01:51 PM
NC
440Jim Offline
440Jim  Offline
NC
From the Earnest technical bulletin that "Darkbreeze" linked.
Re: Flat washers under flywheel bolts? [Re: 440Jim] #3048463
06/06/22 10:34 PM
06/06/22 10:34 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Here are the ARP instructions for their 7/16 flywheel bolts, they do have the undercut head. The other pic is stock flexplate and torque converter bolts...makes me wonder if the differing style is why you get a loose cracked thru the bolt holes plate every once in a while. Reading how the bolts work makes me think stock flexplates are one shot only to be safe.
Re: Flat washers under flywheel bolts? [Re: 440Jim] #3048891
06/08/22 01:07 PM
06/08/22 01:07 PM
moparx Offline
moparx  Offline
thanks for kicking my butt when i needed it Jim ! up
after reading the bulletin, i immediately forgot what i read ! i need to get some of those supplements advertised on late night tv.
i think those products are meant to kill the spiders that make the cobwebs in my noggin. laugh2
i have now printed the bulletin, so i have no excuse to forget what it contains. [except forgetting where i put the print out. biggrin]
beer
Re: Flat washers under flywheel bolts? [Re: moparx] #3048898
06/08/22 01:25 PM
06/08/22 01:25 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
re-reading the ARP instructions makes the use of
a special consistent specification lubricant
under the head of the ARP place bolt
“pop out” in importance
I thereby propose that:
all moparts members should
that from now till death
we will stick our finger into our ear deep enough
to get a bit of
“organic wonder grease”
that we will smear on the underside of every future bolt
Re: Flat washers under flywheel bolts? [Re: 360view] #3048908
06/08/22 01:55 PM
06/08/22 01:55 PM
moparx Offline
moparx  Offline
i was told as a child, you do not stick anything larger than your elbow into your ear ! biggrin
beer
Page 3 of 3 1 2 3
