Re: Power Valve
[Re: 72 RR DUDE]
#2678016
07/16/19 06:00 PM
07/16/19 06:00 PM
RapidRobert
I would think a hesitation/dieing/stumble would be lean (vac leak) & this sounds like that as opposed to a blown PV which would put you on the other end of the spectrum which would be the power circuit would then be on full time & be too rich. (unless a blown PV stays "off") but that still would not make it hesitate/stumble at less than WOT throttle, it'd be like normal part throttle operation when you are on the "cruise" circuit.
Re: Power Valve
[Re: 72 RR DUDE]
#2678057
07/16/19 08:10 PM
07/16/19 08:10 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
Something else to consider is that if the fuel had been getting warm on the highway and when you came to a stop, it got hot which would show up as a lean condition at a stop.
Or, vacuum leak?
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
Re: Power Valve
[Re: 72 RR DUDE]
#2678081
07/16/19 09:30 PM
07/16/19 09:30 PM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
You've got a couple of possibilities for sure. Extra fuel leaking in could be a failure such as Accelerator pump check or power valve - in yoiur case could be due to somehting in th efuel damaging the materials. or could be simple even loose bowl screws depending on the type of gasket (sticky type moer likely to stay sealed). Or an overfilling bowl on decel is another possibility. either due to float setting slightly high or needle sticking, or related to hot vapor pushing fuel in. Chrysler mentions that as early as this '63 MTSC http://www.imperialclub.org/Repair/Lit/Master/188/Page13.htmBut it got more attention in the '70s http://www.imperialclub.org/Repair/Lit/Master/271/Page13.htmThere's even a kit for it that I started a thread about a few years ago. edit: How would the car run? With excess fuel such as overfilled bowl it will flood and die nice and soft as you let off throttle. or may cough and die at full stop. with busted PV it may run ok but rich, requiring more pedal to get it to run well.
Re: Power Valve
[Re: 72 RR DUDE]
#2678128
07/16/19 11:15 PM
07/16/19 11:15 PM
Posts: 43,317 Bend,OR USA
Cab_Burge
Check the float level cold and then go drive it and if it acts up remove the air cleaner and see if the gas is boiling into any of the carbs, if so that may be your problem. BTW, how old was the gas in the tanks when it acted up? Todays pump swill isn't very good in carbs, especially if it is more than a couple of weeks old in the summer ![whiney whiney](/ubbthreads/images/graemlins/custom/whiney.gif)
Re: Power Valve
[Re: 72 RR DUDE]
#2678176
07/17/19 07:46 AM
07/17/19 07:46 AM
Mattax
Phila. Pa.
Well depending on what you saw that may be the problem. From idle to 2000 rpm or so, fuel goes from the bowl to underneath the throttle blades. So if you saw fuel coming out the boosters or any other location above the blade - that's not right. Just like shown in the illustration here: http://www.imperialclub.org/Repair/Lit/Master/273/Page05.htmOnly slight difference from theory to implementation is many carbs have a portion of the transfer slot below the blade at running idle position. Flip back through the pages for the float and bowl stuff. Basically. the bowl is at close to atmospheric pressure and the under the throttle a vacuum is created. That's how the low speed (aka idle) system works.
Re: Power Valve
[Re: Mattax]
#2678197
07/17/19 08:46 AM
07/17/19 08:46 AM
Posts: 2,537 God's Country Maryland
GODSCOUNTRY340
The first thing I'd look for would be fuel dumping into one of the carbs at idle. Look down each carb while idling to see if there's excess fuel dumping into one of them.
Re: Power Valve
[Re: 71rm23]
#2679076
07/19/19 12:24 PM
07/19/19 12:24 PM
Cab_Burge
I'm sure a bad power valve would usually mean a very rich exhaust ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) There has been some very bad misinformation posted on here about having some of fhe transfer slot expose to make the carbs idle good, WRONG ![tsk tsk](/ubbthreads/images/graemlins/custom/tsk.gif) The slots should not be exposed at all below the throttle plates, if they are your carb is not idling on the idle circuit only due to extra fuel being sucked into the motor from the transfer slots I had to find out the hard way that opening the throttle plates enough to expose the transfer slots also allow the power valve circuit to start dumping extra fuel into the carb on low vacuum motors at idle speed with higher rated power valves in the carbs, motor had less than 6.0 vacuum at idle with a 6.5 power valve would load up and die until I increase the idle speed to make more vacuum than 6.5 inches of vacuum at idle speeds ![realcrazy realcrazy](/ubbthreads/images/graemlins/custom/realcrazy.gif) Years ago someone, maybe Holley themselves, started drilling small holes in the throttle blades to allow extra air into the motor to avoid opening the throttle plates enough expose the transfer slots ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) Try removing the lead plugs blocking the outboard carbs. idle circuit mixture screws in the base plates and gently close them up and back them out 1/3 to 1/2 turn only and see if that helps on your problem ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) You can figure this out and fix it ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif)
Re: Power Valve
[Re: 72 RR DUDE]
#2681009
07/24/19 06:41 PM
07/24/19 06:41 PM
fast68plymouth
So. Burlington, Vt.
Needle and seat is stuck more than likely.
Don’t even have to pull the carb for that.
I like to have the fuel level sitting at the bottom of the site plug hole, and not really running out.
Re: Power Valve
[Re: fast68plymouth]
#2681014
07/24/19 06:56 PM
07/24/19 06:56 PM
YO7_A66
Indiana
I agree too. Just unscrew the needle/seat assembly from the top and blow them out with carb cleaner. You will probably find something stuck in one of them. Then screw them back in at about the same height that you found them. Readjust like said above.
Re: Power Valve
[Re: YO7_A66]
#2681018
07/24/19 07:42 PM
07/24/19 07:42 PM
fast68plymouth
So. Burlington, Vt.
Could also be a blown/loose PV....... which would pretty much empty the bowl when the fuel supply stopped pumping.
Re: Power Valve
[Re: 72 RR DUDE]
#2681066
07/24/19 11:14 PM
07/24/19 11:14 PM
Posts: 1,638 Florida
GMP440
Check the needle seat as stated in an earlier posting. I had the same thing happen last year . My 68 Coronet ran great at speed, but the moment I slowed to at a stop sign, the engine was stumbling. This was right after I rebuilt the Holley carburetor. Took the carb off, took out the needle and seat, found the rubber in the needle and seat disintigrated. When I rebuilt the carb I did not replace the needle and seat. Changed it out, reset the float level, installed the carb. Engine ran much better and no stumbling. Even when the car sits for about 8 hours; bump the starter, engine starts right up without pumping the accelerator. The 318 runs great and idles great. The carb is Holley 500 cfm, 2bbl. It's the same as the Holley 350 cfm center board carb on the 6 pack engines. It's an easy carb to rebuild.
Re: Power Valve
[Re: GODSCOUNTRY340]
#2681098
07/25/19 06:06 AM
07/25/19 06:06 AM
Posts: 4,321 Prospect, PA
BSB67
Prospect, PA
The first thing I'd look for would be fuel dumping into one of the carbs at idle. Look down each carb while idling to see if there's excess fuel dumping into one of them. This. It takes 20 seconds to do this and you'll know if it's a needle & seat. Get someone to help if it won't idle. Actually you can start the car from under the hood and hand throttle it and then you'll know.
