Re: Front end alignment prices?
[Re: Lee446]
#2676947
07/12/19 11:33 PM
07/12/19 11:33 PM
Posts: 5,366 Rancho Cordova, California (Sa...
hemi71x
Well, your in a large metropolitan major city. What are shop hour labor rates going for in Houston, these days? Around my area, labor rates are easily $120.00 + dollars an hour, so maybe they figure, up front, from the beginning, that your old dinosaur will be giving them trouble, and be time consuming to get done, than just toe settings on modern cars.
RF-4C Phantom 69-370 Zweibrucken, Germany
[Re: Lee446]
#2677020
07/13/19 10:29 AM
07/13/19 10:29 AM
Posts: 18,160 Mass
DAYCLONA
Mass
Two of the local shops that are willing and capable of doing an alignment on our old Mopars are charging $150 !! Why in the world is it that high and is there really more involved, labor-wise, than most modern cars? Or are they just trying to take advantage of classic car owners? This was on my 70 Cuda. $100+ is just about right...also depends on the area, are you a repeat customer? and if the shop has the latest alignment rack/equipment it needs to make some $$$$ to pay it self off..... and
[Re: DAYCLONA]
#2677027
07/13/19 10:48 AM
07/13/19 10:48 AM
Posts: 1,379 Houston,Tx.
Lee446
Houston,Tx.
A shop that I used for over forty years went from $75 to $150 in the space of two years, that is how long it had been since I needed an alignment on an old car. The shop I went to earlier this week, charged me $100 on my 69 Sat last month, and $150 on the Cuda this week, but in all fairness, when I took the Satelite in, the owner was there and told me he normally gets $150, but was giving me a break because I was recommended by a mutual friend who owns a repair shop. There are shops around that get in the $75 range, I tend to think, that some businesses tend to push prices just to see what the traffic will bear, especially with "Toy Cars". That is why I made the post, just to get an idea of what the average prices are around the country.
[Re: Lee446]
#2677066
07/13/19 01:24 PM
07/13/19 01:24 PM
Posts: 15,656 Omaha Ne
TJP
Omaha Ne
I have a fairly new hunter system. By the time we get the car on the rack, put the plates under the tires (we do not have an alignment rack), Check the tire pressures, mount the heads, calibrate the heads, perform the alignment, undo everything, test drive to make sure all is good. Do the kwik detail and paper work I have over half a day in the job. At 150.00 I would be losing about twice that. That is why I typically only do the alignments for well established customers or after we've done suspension work. Others I refer to a local frame shop. i do not know what they charge but I'm guessing 150-200. The same applies to oil changes, I lose my backside on everyone. Hope this helps explain from the other side of the fence ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: bbtrux]
#2677067
07/13/19 01:31 PM
07/13/19 01:31 PM
TJP
Omaha Ne
If you were the shop owner , would you go into that job without assuming that theres no way any of the cam bolts arent frozen? Price is fair. Speaking of frozen cam bolts we had a 68 Dart a few weeks back that took about 6 hours to get the upper bolts out of. What a PITA
[Re: TJP]
#2677078
07/13/19 02:05 PM
07/13/19 02:05 PM
Posts: 19,878 north of coder
moparx
over the years, i have assembled all the tools necessary for doing the alignments on my junk. there are many reasons for this, but primarily, there are no shops locally i can trust to get me the specs i want, and i'm not going to be taking vehicles back 3-4 times to "get it close". as was said previously, toe is the only setting on new stuff unless you obtain [or fab up] caster/camber plates. the older stuff really responds to lots of caster, a good camber curve, and elimination of bump steer, but you have to work to get these advantages. this may take way more than most will want, or can, do. therefore, i only do alignments for myself. i know what's involved, what i want, and what i can accomplish. also, the older i get, the harder it is to do. hopefully, when i can no longer do this, i can find some young buck that will want to know how, and i can teach him. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: moparx]
#2677085
07/13/19 02:30 PM
07/13/19 02:30 PM
Posts: 6,395 nowhere
Sniper
nowhere
over the years, i have assembled all the tools necessary for doing the alignments on my junk. there are many reasons for this, but primarily, there are no shops locally i can trust to get me the specs i want, and i'm not going to be taking vehicles back 3-4 times to "get it close". as was said previously, toe is the only setting on new stuff unless you obtain [or fab up] caster/camber plates. the older stuff really responds to lots of caster, a good camber curve, and elimination of bump steer, but you have to work to get these advantages. this may take way more than most will want, or can, do. therefore, i only do alignments for myself. i know what's involved, what i want, and what i can accomplish. also, the older i get, the harder it is to do. hopefully, when i can no longer do this, i can find some young buck that will want to know how, and i can teach him. ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: Sniper]
#2677175
07/13/19 08:58 PM
07/13/19 08:58 PM
Posts: 3,378 Rancho Cordova, CA
Exit1965
Rancho Cordova, CA
Along the lines of what Moparx said..
I'm the type that doesn't like to take my Mopars to anyone to do anything so I do it myself. Alignment isn't hard. I did it on my Dart, first time doing it, and was kind of shocked how easy it was and how well it drove on my first home alignment job. Then I wondered why anyone who likes to do work on old cars (e.g. replacing the engine/trans, suspension parts etc.) would bother taking it to a shop just for that. Seems there is some idea out there that alignment must be done at a shop. Toe in is easy with some string, and you can get a camber/caster gauge and use some tiles for turn plates. With the # of miles I put on the car being quite low, all I really care about is does it drive straight and stable. A professional alignment might be more accurate somehow, but if you can't feel the difference when driving it, and the front tires aren't eating themselves alive, I for one am happy to do what I can in the garage or driveway.
That said, if I was for some reason dead set on having someone else do it, $150 or even more for something you'll hopefully only do once doesn't seem that bad. At that point it would be more about finding people you can trust to do what you want, which might include leaving the front end height where it is.
[Re: Exit1965]
#2677176
07/13/19 09:03 PM
07/13/19 09:03 PM
RapidRobert
^^^ X2 & check the utube vids. #1 get the ride height where you want it (front wheels/tires look good in the wheelwell).
[Re: moparx]
#2677187
07/13/19 09:31 PM
07/13/19 09:31 PM
Posts: 30,622 Florida STAYcation
72,000!.Fu.Ah !
Still king of the village idiots
Florida STAYcation
over the years, i have assembled all the tools necessary for doing the alignments on my junk. there are many reasons for this, but primarily, there are no shops locally i can trust to get me the specs i want, and i'm not going to be taking vehicles back 3-4 times to "get it close". as was said previously, toe is the only setting on new stuff unless you obtain [or fab up] caster/camber plates. the older stuff really responds to lots of caster, a good camber curve, and elimination of bump steer, but you have to work to get these advantages. this may take way more than most will want, or can, do. therefore, i only do alignments for myself. i know what's involved, what i want, and what i can accomplish. also, the older i get, the harder it is to do. hopefully, when i can no longer do this, i can find some young buck that will want to know how, and i can teach him. Come on now mopX ... admit it .... you are a guy of many skills but your assistant completes you ... the Ms Daisy Dukes ! ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif)
[Re: TJP]
#2677202
07/13/19 10:30 PM
07/13/19 10:30 PM
Posts: 10,577 Rittman Ohio
fourgearsavoy
Rittman Ohio
I have a fairly new hunter system. By the time we get the car on the rack, put the plates under the tires (we do not have an alignment rack), Check the tire pressures, mount the heads, calibrate the heads, perform the alignment, undo everything, test drive to make sure all is good. Do the kwik detail and paper work I have over half a day in the job. At 150.00 I would be losing about twice that. That is why I typically only do the alignments for well established customers or after we've done suspension work. Others I refer to a local frame shop. i do not know what they charge but I'm guessing 150-200. The same applies to oil changes, I lose my backside on everyone. Hope this helps explain from the other side of the fence Over half a day in the job ? ![confused confused](/ubbthreads/images/graemlins/custom/confused.gif) The most time I ever had to spend was getting a big block duster dialed in and that was about 2 hours. I use a new Hunter rack and it takes about 10 minutes to set up and compensate the heads. I've done about a dozen old Mopars on it but I do insist that all the cams move before you bring it to me and I charge $50-$75 depending on how long it takes. Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: moparx]
#2677203
07/13/19 10:37 PM
07/13/19 10:37 PM
Posts: 8,172 New Mexico
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
over the years, i have assembled all the tools necessary for doing the alignments on my junk. there are many reasons for this, but primarily, there are no shops locally i can trust to get me the specs i want, and i'm not going to be taking vehicles back 3-4 times to "get it close". as was said previously, toe is the only setting on new stuff unless you obtain [or fab up] caster/camber plates. the older stuff really responds to lots of caster, a good camber curve, and elimination of bump steer, but you have to work to get these advantages. this may take way more than most will want, or can, do. therefore, i only do alignments for myself. i know what's involved, what i want, and what i can accomplish. also, the older i get, the harder it is to do. hopefully, when i can no longer do this, i can find some young buck that will want to know how, and i can teach him. It took me a few hrs, each adjustment affects another so it was a process.
[Re: moparx]
#2677225
07/13/19 11:36 PM
07/13/19 11:36 PM
Posts: 2,892 Pattison Texas
CSK
Pattison Texas
over the years, i have assembled all the tools necessary for doing the alignments on my junk. there are many reasons for this, but primarily, there are no shops locally i can trust to get me the specs i want, and i'm not going to be taking vehicles back 3-4 times to "get it close". as was said previously, toe is the only setting on new stuff unless you obtain [or fab up] caster/camber plates. the older stuff really responds to lots of caster, a good camber curve, and elimination of bump steer, but you have to work to get these advantages. this may take way more than most will want, or can, do. therefore, i only do alignments for myself. i know what's involved, what i want, and what i can accomplish. also, the older i get, the harder it is to do. hopefully, when i can no longer do this, i can find some young buck that will want to know how, and i can teach him. Yes THIS ^^^^^ I do the same thing.
[Re: 72,000!.Fu.Ah !]
#2677282
07/14/19 10:08 AM
07/14/19 10:08 AM
moparx
Come on now mopX ... admit it .... you are a guy of many skills but your assistant completes you ... the Ms Daisy Dukes ! hay DoC, i just completed a 376mi round trip to carlisle in the "duke bus" without even giving it a simple "string" measurement for toe, and it drove straight and true with your hands off the wheel ! i will have to check it though, when i get a few hours. YoU are right, however, about Ms "Daisy" complementing me. as of july 20, we will have been together 40 blissful years ! ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: fourgearsavoy]
#2677325
07/14/19 01:49 PM
07/14/19 01:49 PM
TJP
Omaha Ne
I have a fairly new hunter system. By the time we get the car on the rack, put the plates under the tires (we do not have an alignment rack), Check the tire pressures, mount the heads, calibrate the heads, perform the alignment, undo everything, test drive to make sure all is good. Do the kwik detail and paper work I have over half a day in the job. At 150.00 I would be losing about twice that. That is why I typically only do the alignments for well established customers or after we've done suspension work. Others I refer to a local frame shop. i do not know what they charge but I'm guessing 150-200. The same applies to oil changes, I lose my backside on everyone. Hope this helps explain from the other side of the fence Over half a day in the job ? ![confused confused](/ubbthreads/images/graemlins/custom/confused.gif) The most time I ever had to spend was getting a big block duster dialed in and that was about 2 hours. I use a new Hunter rack and it takes about 10 minutes to set up and compensate the heads. I've done about a dozen old Mopars on it but I do insist that all the cams move before you bring it to me and I charge $50-$75 depending on how long it takes. Gus Please read the first part of my comment again. By the time we get the car on the rack, put the plates under the tires (we do not have an alignment rack), Check the tire pressures, mount the heads, calibrate the heads, perform the alignment, undo everything, test drive to make sure all is good. Do the kwik detail and paper work I have over half a day in the job. If I had a dedicated bay and was not starting from scratch ( all new front end) it would be a substantial time savings. That is why I typically only do the alignments for well established customers or after we've done suspension work. Others I refer to a local frame shop. i do not know what they charge but I'm guessing 150-200. In addition we also give the car a kwik inspection as well as check fluid levels etc. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
