Re: What are the interchangability of 8 3/4s?
[Re: TJP]
#2676908
07/12/19 08:34 PM
07/12/19 08:34 PM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
The SG fits all.Gears are case specific.There are IIRC 2 different splines for the U joint yoke though and there are 2 different sizes.They are case specific also.Rocky
Chrysler Firepower
[Re: roadrunninMark]
#2676921
07/12/19 09:10 PM
07/12/19 09:10 PM
Posts: 43,213 Bend,OR USA
Cab_Burge
All three of the modern, made after 1962, third members came with the course spline pinion gears and both size U joints. Some of the 1969 and later third members came with the fine spline pinion gears also As already pointed out the carriers, 741,742 and the later 489 cases all have specific pinion gear diameter and specific bearing race sizes so the gears will not interchange between them
[Re: Cab_Burge]
#2676927
07/12/19 09:29 PM
07/12/19 09:29 PM
Posts: 6,277 nowhere
Sniper
nowhere
All three of the modern, made after 1962, third members came with the course spline pinion gears and both size U joints. Some of the 1969 and later third members came with the fine spline pinion gears also As already pointed out the carriers, 741,742 and the later 489 cases all have specific pinion gear diameter and specific bearing race sizes so the gears will not interchange between them What Cab said, the factory put them all out in both sizes.
[Re: Cab_Burge]
#2677004
07/13/19 09:40 AM
07/13/19 09:40 AM
Posts: 2,943 GA
roadrunninMark
GA
