AFB accelerator pump..what one is best to use? #2676383
07/10/19 08:02 PM
07/10/19 08:02 PM
cincinnati ohio
mcat4321 Offline OP
mcat4321  Offline OP
cincinnati ohio
im working on a 66 426 hemi the accelerator pump on the rear carb is junk, it will only pump on the last half inch of the stroke.. i feel the spring is to weak and absorbing to much of the movement.. i got one off amazon (from china) junk, its rubber and just wont work either..what is everyone else using?
Re: AFB accelerator pump..what one is best to use? [Re: mcat4321] #2676391
07/10/19 08:34 PM
07/10/19 08:34 PM
Badham Co.
Y
Y3 70 BEE Offline
Y3 70 BEE  Offline
Y
Badham Co.
Leather
Re: AFB accelerator pump..what one is best to use? [Re: mcat4321] #2676395
07/10/19 08:35 PM
07/10/19 08:35 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Edelbrock part#1468 if it's not a 800 cfm AFB
Re: AFB accelerator pump..what one is best to use? [Re: Sammy] #2676428
07/10/19 10:32 PM
07/10/19 10:32 PM
run a screwdriver lightly around the perimeter between the spring & the inside of the leather to expand it slightly
Re: AFB accelerator pump..what one is best to use? [Re: RapidRobert] #2676463
07/11/19 12:24 AM
07/11/19 12:24 AM
Washington
madscientist Offline
Washington
The Edelbrock accelerator pump doesn't work in some of the Carter main bodies. I'll look tomorrow and hopefully I can find the card of the business that I found who has the correct pump for the Carter carb. I was going through pumps like poop through a goose until I found this company. The one I bought from them is over two years old and working like a champ.
Re: AFB accelerator pump..what one is best to use? [Re: madscientist] #2676484
07/11/19 07:19 AM
07/11/19 07:19 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
that carb takes the small 1968 and down pump. look on line and there are some afb carb parts vendors.
Re: AFB accelerator pump..what one is best to use? [Re: mcat4321] #2676541
07/11/19 11:32 AM
07/11/19 11:32 AM
Try putting some motor oil on it and run a small thin round drill bit gently between the inner surface and the spring to spread it out scope up
Re: AFB accelerator pump..what one is best to use? [Re: mcat4321] #2676542
07/11/19 11:36 AM
07/11/19 11:36 AM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: AFB accelerator pump..what one is best to use? [Re: Cab_Burge] #2676559
07/11/19 12:44 PM
07/11/19 12:44 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I’ve had good luck with kits for my 70 avs from Mikes Carburetor Shop.
Re: AFB accelerator pump..what one is best to use? [Re: fastmark] #2676561
07/11/19 01:01 PM
07/11/19 01:01 PM
Washington
Washington
If that's the place out here in Washington, that was the guy I use. Can't find the car, but that sounds correct. Damn filing system of mine is pretty crappy.
Re: AFB accelerator pump..what one is best to use? [Re: madscientist] #2676622
07/11/19 05:33 PM
07/11/19 05:33 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Yes. That’s him.
