Re: AFB accelerator pump..what one is best to use?
[Re: Sammy]
#2676428
07/10/19 10:32 PM
07/10/19 10:32 PM
RapidRobert
run a screwdriver lightly around the perimeter between the spring & the inside of the leather to expand it slightly
[Re: RapidRobert]
#2676463
07/11/19 12:24 AM
07/11/19 12:24 AM
Posts: 4,457 Washington
madscientist
Washington
The Edelbrock accelerator pump doesn't work in some of the Carter main bodies. I'll look tomorrow and hopefully I can find the card of the business that I found who has the correct pump for the Carter carb. I was going through pumps like poop through a goose until I found this company. The one I bought from them is over two years old and working like a champ.
[Re: fastmark]
#2676561
07/11/19 01:01 PM
07/11/19 01:01 PM
madscientist
Washington
I’ve had good luck with kits for my 70 avs from Mikes Carburetor Shop. If that's the place out here in Washington, that was the guy I use. Can't find the car, but that sounds correct. Damn filing system of mine is pretty crappy.
