Re: Seat Belt Interlock on 1973 Plymouth?
[Re: mopars4ever]
#2674275
07/04/19 11:57 PM
07/04/19 11:57 PM
Posts: 16,840 Between Houston & Galveston TX
SattyNoCar
Seat belt interlock systems have this bypass button mounted on the firewall near the ECU. Speaking of the ECU, does it have a GOOD ground? I've had issues with the self tapping bolts coming loose. On my wagon, I ran one of those narrow braided ground straps from the ECU to the block itself. Where the strap attached to the ECU, I used a nut and bolt rather than the self tapping bolt. (not this exact one, just shown as an example)
John
The dream is dead, long live the dream.......š„
[Re: SattyNoCar]
#2674675
07/06/19 04:19 AM
07/06/19 04:19 AM
Posts: 6,098 Valencia, EspaƱa
NachoRT74
Valencia, EspaƱa
Seatbelt light began on 71 being time delay relay controled.
Then 72 and 73 began to be controled by seats and seatbelt retractor sensors, just as a warning buzz and light system
74 began to be interlocked, also with sensors ( this time seatbelt sensors on female buckles ), but just on USA models. Canadian for example even still working and wired the same as USA models, still allowed to crank the engine using a diff control box unit.
