which vacuum pump for big cam power brakes?
#2673385
07/02/19 09:36 PM
07/02/19 09:36 PM
Posts: 1,797 BC Canada
ogopogo
BC Canada
our 340 challenger is only making 7.5in vac at idle and the brakes are not great.I want to keep the power brakes and would prefer not to spend a pile of money on the pump since this motor is only staying in the car for a few months than a 5.7 hemi is going in.Any recommendations for reasonably inexpensive reasonably quiet vac pump options? Maybe a junkyard oem setup or? I tried a cannister today but was a waste of money,need a pump it seems....
Re: which vacuum pump for big cam power brakes?
[Re: 71rm23]
#2673405
07/02/19 10:22 PM
07/02/19 10:22 PM
Posts: 6,291 nowhere
Sniper
nowhere
How is rebuilding the booster going to make 7.5 inches of vacuum work? One idea caddy vacuum pumpNot super cheap though.
[Re: ogopogo]
#2673563
07/03/19 12:15 PM
07/03/19 12:15 PM
Posts: 18,157 Mass
DAYCLONA
Mass
our 340 challenger is only making 7.5in vac at idle and the brakes are not great.I want to keep the power brakes and would prefer not to spend a pile of money on the pump since this motor is only staying in the car for a few months than a 5.7 hemi is going in.Any recommendations for reasonably inexpensive reasonably quiet vac pump options? Maybe a junkyard oem setup or? I tried a cannister today but was a waste of money,need a pump it seems.... D. You need a minimum of 10 inches vac with a manual tranny vehicle, and at least 12 inches with an auto to have safe repeatable braking... I've used the SSBC vacuum pump with good success along with a vac resv canister, the pump is going to make some noise when it's running, just try and mount it on rubber pads/feet to limit the noise/vibration, I hid it in the front fender behind the headlight, and the vac resv canister under the battery tray to keep the engine compartment clean and factory looking FYI: I had the SSBC pump on a 472 HEMI/auto with a big cam and a dual diaphragm Bendix booster, initially I could only get about 8" of vac, the SSBC/resv canister was good for a steady 14-15" of vac, and steady repeatable braking and good vacuum recovery Mike
[Re: ogopogo]
#2673728
07/03/19 06:23 PM
07/03/19 06:23 PM
Posts: 6,567 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
thanks for the tips guys...im rethinking the whole deal today...possibly easier just to switch the car to manual brakes for the summer or better solution is a smaller camshaft which i was hoping to avoid.Having alot of trouble tuning the carb with the low vacuum and of course the car wants to load up and or die when put into gear or idling in gear at a stoplight with auto trans,stock converter and 355s..... Just trying to decide which is gonna be the least amount of hassle/best results!
BTW this was a mystery motor that came in on an old car deal so had no idea it had such a big cam in it .... How much initial timing do you run? Big cams usually like as much initial as the starter can take. Kevin
