Compressor draining
#2672098
06/30/19 08:41 PM
06/30/19 08:41 PM
Posts: 28 New Jersey
Claw57
New Jersey
I have a 30 gallon horizontal tank oil less compressor. I usually only use it about once a week and I would drain it after each use, but I think I'm going to start using it daily. Probably only about 2-3 hours after work. The question is should I drain it after each use, or would it be okay to just drain it weekly? It seems like it would be a lot of wear to fill it and drain it every day.
Because I like it that way.
Re: Compressor draining
[Re: moparx]
#2672543
07/01/19 01:35 PM
07/01/19 01:35 PM
RapidRobert
^^^ me too (daily). shop owner request.
[Re: moparx]
#2672624
07/01/19 04:53 PM
07/01/19 04:53 PM
Posts: 30,465 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
how much water was in that tank ? i drain my compressor after each use. It was almost completely FULL ! .., 80 or so gallons IIRC !! Now as much HOT HUMID AIR as you expell .... I can see Yurr need to drain daily !
[Re: dOc !]
#2673055
07/02/19 02:04 PM
07/02/19 02:04 PM
Posts: 4,952 northwest USA
NANKET
northwest USA
To the guys that drain after every use .... you realize that it takes many hours for the hot compressed air to cool and then water separates from the air There you go again interjecting pertinent facts into these threads. LOL. Carry on.
