Re: Timing Issue
[Re: Cab_Burge]
#2672542
07/01/19 01:33 PM
07/01/19 01:33 PM
RapidRobert
have a non dialback you could try. What Cab said either a dist prob or the light. 2&1/4" (2.246") CW from the TDC slit is 35.5 degrees.
Re: Timing Issue
[Re: maximus]
#2672660
07/01/19 06:01 PM
07/01/19 06:01 PM
RapidRobert
Gary do you have another dist you can toss in for a test?
Re: Timing Issue
[Re: maximus]
#2672688
07/01/19 06:51 PM
07/01/19 06:51 PM
RapidRobert
I agree, we're missing something simple
Re: Timing Issue
[Re: topside]
#2672948
07/02/19 10:37 AM
07/02/19 10:37 AM
Posts: 957 MI, Lapeer
maximus
MI, Lapeer
Using two different non-dial back timing lights. Both show the same results. 34 degrees with no movement of timing over the rpm range.
Re: Timing Issue
[Re: maximus]
#2672982
07/02/19 11:41 AM
07/02/19 11:41 AM
Posts: 2,673 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Unless the 34 degrees is giving you a problem starting I wouldn't worry about it. Some people prefer to have it locked anyway.
2011 Drag Pak Challenger
Re: Timing Issue
[Re: maximus]
#2672983
07/02/19 11:41 AM
07/02/19 11:41 AM
Posts: 4,457 Washington
madscientist
Washington
Using two different non-dial back timing lights. Both show the same results. 34 degrees with no movement of timing over the rpm range. This is a stumper. If it was me (laz-z-boy tuner giving worthless advice) I'd see if I could find someone local with a distributor machine and have them spin both of them up. And then you can maybe get a better handle on what is happening and take some variables out of the equation.
Re: Timing Issue
[Re: maximus]
#2672984
07/02/19 11:42 AM
07/02/19 11:42 AM
RapidRobert
put the dampener at 15 BTDC #1 compression (or what your preferred initial # is) & turn the housing till the tooth is dead even with the magnet with the rotor under the #1 plug wire dist cap terminal (I'm assuming your Rotor Phasing is acceptable) & lock it down. timing light trigger clamp on #1 plug wire (not being rude just covering everything). fire it up & see what happens. I still think it is a MSD issue.
Re: Timing Issue
[Re: RapidRobert]
#2673029
07/02/19 01:19 PM
07/02/19 01:19 PM
Posts: 11,652 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
The weights being free to move will not matter if the advance mechanism is jammed/locked. With the unit installed or the shaft being held, you should be able to turn the rotor/reluctor assembly to some degree (1/4"-3/8") and have it be pulled back to the base location by the springs. Obviously, the unit with the heavy springs will require more effort to turn, but neither should require a lot of effort to move.
Re: Timing Issue
[Re: maximus]
#2673289
07/02/19 05:20 PM
07/02/19 05:20 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Big cam? You may like it better with the advanced all in at idle once it's all said and done.
Re: Timing Issue
[Re: CMcAllister]
#2673437
07/02/19 11:52 PM
07/02/19 11:52 PM
Posts: 304 Portland, Oregon
Digger73
Portland, Oregon
Just spit balling here but could the distributors be for a small block? If I remember right the shaft is the same length as an RB or Hemi.....
Digger73 (Mike)
I live with fear everyday but, sometimes she lets me race!
