Re: 440 Blocks
[Re: LA360]
#2672844
07/02/19 05:10 AM
07/02/19 05:10 AM
Posts: 2,459 Sydney,Australia
tex013
Sydney,Australia
Plus there's just something about the sound of a BB that a SB can't make. Is it7 because they're like a kid with asthma trying to run? Ouch Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
Re: 440 Blocks
[Re: tex013]
#2672848
07/02/19 05:55 AM
07/02/19 05:55 AM
Posts: 2,410 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
I ran an injected alcohol 499 low deck for approximately 10 years, 1-300 1/8 mile passes every year, 750ish hp, arp main studs and aluminum main caps, eagle crank, rods and Ross pistons, half fill, finally cracked a cylinder wall on #8...never saw a web crack...shifted at 6800, don't know if it makes a difference but this block was first in a hardtail pipe rack then a 4 link pipe rack, spanned 1998 to 2008. Scattered it all over Denton Dragway after sleeving the cracked #8 hole...( 5 Dyno pulls, 3rd pass down the track) damage was do severe myself and 2 "experts" couldn't figure out what let go first...managed to save the intake, distributor and fuel injection system...oh yeah and valve covers...(most likely suspect was something to do with 7&8 rod journal)...
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
Re: 440 Blocks
[Re: LA360]
#2672940
07/02/19 10:26 AM
07/02/19 10:26 AM
Posts: 1,237 North Central, Indiana
Roughbird72
Plus there's just something about the sound of a BB that a SB can't make. Is it because they're like a kid with asthma trying to run?
72 Plymouth Roadrunner 11.08@123.25
Re: 440 Blocks
[Re: Roughbird72]
#2672958
07/02/19 10:47 AM
07/02/19 10:47 AM
Posts: 20,163 PA.
pittsburghracer
"Little"John
"Little"John
PA.
It doesn’t take much of a small block to make the big blocks look silly. How many 340-360 blocks do you hear about cracking. 😂
Re: 440 Blocks
[Re: als499]
#2672985
07/02/19 11:43 AM
07/02/19 11:43 AM
Posts: 4,457 Washington
madscientist
Washington
This 440 block still ran fine , low 10's , but smoked a bit... Looks like the number 4 cylinder is cracked WAY up the bore. It must be filled or it would have put coolant in the oil.
Re: 440 Blocks
[Re: tex013]
#2673376
07/02/19 09:03 PM
07/02/19 09:03 PM
Posts: 6,136 Melbourne , Australia
LA360
Plus there's just something about the sound of a BB that a SB can't make. Is it7 because they're like a kid with asthma trying to run? Ouch Tex You have to admit, the BBM heads out there aren't exactly setting the world on fire in terms of airflow/cross section. No idea what the Chrysler engineers were thinking really. No offense intended to anyone with asthma!
Alan Jones
Re: 440 Blocks
[Re: LA360]
#2673422
07/02/19 11:16 PM
07/02/19 11:16 PM
tex013
Sydney,Australia
Plus there's just something about the sound of a BB that a SB can't make. Is it7 because they're like a kid with asthma trying to run? Ouch Tex You have to admit, the BBM heads out there aren't exactly setting the world on fire in terms of airflow/cross section. No idea what the Chrysler engineers were thinking really. No offense intended to anyone with asthmTa! I guess it was hemi those max wedge ports work , nearly as good as a sbc Tex
Re: 440 Blocks
[Re: RemCharger]
#2673499
07/03/19 08:26 AM
07/03/19 08:26 AM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
I have not cracked one, but the highest HP I've put through one at the track was around 620 hp. It was/is a 14:1 stock stroke 440 that ran 10.40s at 128-129 mph at 3700 lbs. Ran it for a lil over 3 years and never hurt it. That same motor is in another car but is making around 700 hp now. It is probably a time bomb, but I'll run it til it dies...if I ever get the rest of the car track worthy.
I know Mike Daurity split the main webs and a couple cylinder walls in his low deck 512/400 stroker in his street car '69 super bee a few years ago. It's around 600 hp on motor plus a small plate system.
