440 Blocks
#2671174
06/28/19 03:01 PM
06/28/19 03:01 PM
Posts: 1,774 Keymar, MD
DusterKid
Keymar, MD
Always hear about 440 blocks cracking. Would like to do a poll to see who has personally have/haven't cracked a block. (Cracked caused by stress, etc, not from a rod breaking and going out the side, etc.)
Re: 440 Blocks
[Re: DusterKid]
#2671192
06/28/19 03:31 PM
06/28/19 03:31 PM
Posts: 4,682 On the parachute mount
n20mstr
I have an RB that I have used...went 9.0's with nitrous in a 3600lb car. Alum rods, stock stroke and stock main caps I have been told..."keep it from detonating, it might live"....and " if it don't crack right away, it might last.."
Its sitting in my basement now, and I keep telling myself im going to use that shortblock again someday
I voted NO
....BAD A$$ STREET CAR.....
Re: 440 Blocks
[Re: n20mstr]
#2671245
06/28/19 05:43 PM
06/28/19 05:43 PM
Posts: 20,179 PA.
pittsburghracer
"Little"John
"Little"John
PA.
275 passes running 8.60’s in my Daytona. 440source assembly and their steel caps. When I tore it down for rebuild it was cracked up thru the mains. It never leaked a drop of water.
Re: 440 Blocks
[Re: pittsburghracer]
#2671255
06/28/19 06:14 PM
06/28/19 06:14 PM
Posts: 43,205 Bend,OR USA
Cab_Burge
275 passes running 8.60’s in my Daytona. 440source assembly and their steel caps. When I tore it down for rebuild it was cracked up thru the mains. It never leaked a drop of water. I've seen the same thing he has, aluminum rods with a stock stroke OEM forged steel crankshaft cracked between #1 nd #3 cylinders at the bottom of the cylinder walls into the #2 main webbing through it to the bearing surface I had a OEM 426 M.W. block crack the same place but it broke a rod due to spinning the #1 rod bearing and the rod broke and hit the side of the block on the left front
Re: 440 Blocks
[Re: Cab_Burge]
#2671280
06/28/19 07:02 PM
06/28/19 07:02 PM
Posts: 14,502 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
3 customer motors.
2- 440’s and a 493.
575hp, 625hp, 695hp
And easily a dozen or more cracked stock steel 440 cranks after they’ve been in bracket cars for a while........usually multiple cracks. Actually....... more uncommon to have it not be cracked.
Re: 440 Blocks
[Re: fast68plymouth]
#2671345
06/28/19 10:33 PM
06/28/19 10:33 PM
Posts: 20,179 PA.
pittsburghracer
"Little"John
"Little"John
PA.
3 customer motors.
2- 440’s and a 493.
575hp, 625hp, 695hp
And easily a dozen or more cracked stock steel 440 cranks after they’ve been in bracket cars for a while........usually multiple cracks. Actually....... more uncommon to have it not be cracked. But when I was running high 9’s with Stock cranks after 3 years when I did a rebuild I stopped even magnifluxing then. They always showed cracks so I just started over with a fresh crank and threw that one on the scrap pile
Re: 440 Blocks
[Re: DusterKid]
#2671441
06/29/19 09:17 AM
06/29/19 09:17 AM
Posts: 4,206 New York
polyspheric
New York
I see the pattern of where they can break. My question: IDT future breakage can be accurately predicted by HP alone. Exactly what factors are involved? Actual maximum cylinder pressure at highest point too near TDC (like nitrous) Very low rod ratio (4-1/2" stroke, BBC + .400" rod = 1.45:1) Knock Crank stiffness (worse with stroke increase, BBC rod journal) B size mains (smaller crank, more saddle and cap area) vs. RB (bigger crank, smaller caps)
IIRC generally accepted that supercharged power is easier on the bottom end because the max cylinder pressure is less (than the same power NA) and occurs over a longer rotation period. But how much?
Boffin Emeritus
Re: 440 Blocks
[Re: DusterKid]
#2671484
06/29/19 10:57 AM
06/29/19 10:57 AM
Posts: 119 SE VA
hemibee69
SE VA
I personally have cracked 2 different stock 440 blocks, couple hundred runs on each i guess. No girdle or block filler. #2 main saddle cracked up into the cyl wall, same place both blocks. Water in the oil the first clue. Did not throw a rod either time. Took it apart as soon as the milky oil showed up. Eagle 4.15" crank, eagle rods, weisco pistons, B1BS heads, Alum main caps both times. 35 deg timing, 9.00 @ 145 2800lbs, 7200 rpm at the stripe.. Put a world block in no more cracks, 8 years later. On a side note I put 600 runs on aa stock block, crank, main caps, no girdle or block fill. But it had aluminum rods, the rods had .25" side clearance from rubbing on the crank sides. You know what the old saying" it is just a matter of time before a stock block fails at higher power levels. John
1969 Orig Hemi Super Bee Post 4 spd Red on Red (Sold sadly) 1970 Cuda Drag car 500" B1/BS 8.63 @ 155 mph 1970 Challenger SE 383 4 bbl A/C PB PS Leather 1971 Orig 440+6 Cuda 4 spd Shaker In-Violet
Re: 440 Blocks
[Re: FastOrange]
#2671621
06/29/19 04:12 PM
06/29/19 04:12 PM
Posts: 1,237 North Central, Indiana
Roughbird72
Even using an ARP main stud kit, Upon inspection, my main caps machined mating surfaces, show fretting damage. In other words, the caps are moving. I suspect at high RPM loads in the 675 HP range. Sold off several stock blocks when the World Blocks debuted. Unfortunately, the World blocks ceased production. I doubt you'll find caps that don't walk in anything that's being twisted harder than passenger car use.
72 Plymouth Roadrunner 11.08@123.25
Re: 440 Blocks
[Re: Roughbird72]
#2671661
06/29/19 06:55 PM
06/29/19 06:55 PM
Posts: 9,845 MI, usa
dvw
MI, usa
Unported-1 Indys, stock cross ram, .650 roller, 4.150 Mopar crank, 498, 660hp, never saw 6900rpm. Pulled the front 2 main webs right out of the block. Broke the crank in half right in front of the #3 main. Doug
