68 440 thermostat housing for AC #2670559
06/27/19 09:01 AM
06/27/19 09:01 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
I’m trying to find a replacement water neck/thermostat housing that will work with the original ac compressor. The straight one will just not fit. I used this one several years ago when we first built this motor. It was from a 67 440 with ac. Now the customer is back for a variety of repairs and it has some pinholes. Does anyone know of a source for these or at least a replacement that looks close?
Re: 68 440 thermostat housing for AC [Re: fastmark] #2670597
06/27/19 10:29 AM
06/27/19 10:29 AM
moparx Offline
moparx  Offline
i am looking for something similar, although in aluminum, for the engine i am assembling for my charger.
your topic is of interest to me as well.
beer
Re: 68 440 thermostat housing for AC [Re: fastmark] #2670603
06/27/19 10:41 AM
06/27/19 10:41 AM
NY
twodoorpost Offline
twodoorpost  Offline
NY
PM sent
Re: 68 440 thermostat housing for AC [Re: twodoorpost] #2670676
06/27/19 01:21 PM
06/27/19 01:21 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
65 Barracuda 273 outlet
Four seasons
Motorad
Dorman
MOPAR 1855605
Re: 68 440 thermostat housing for AC [Re: Sniper] #2670803
06/27/19 05:47 PM
06/27/19 05:47 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Thanks. Just straight ones showed up on a 68 440 search. Ordered one at O’riellys so I should be in business.
Re: 68 440 thermostat housing for AC [Re: fastmark] #2670915
06/27/19 10:08 PM
06/27/19 10:08 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
It appears to be a 66 and earlier thing. Not sure why your 68 needs one.
Re: 68 440 thermostat housing for AC [Re: Sniper] #2670992
06/28/19 07:32 AM
06/28/19 07:32 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
That's what I thought.
Do you have the right year water pump housing?
Re: 68 440 thermostat housing for AC [Re: Morty426] #2670998
06/28/19 07:45 AM
06/28/19 07:45 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
I have an alum housing on it that should be just like the later style 68-69. The problem is the ac compressor is right on top of the water neck. These brackets are not the original one on the car. He bought this car at 17 and tossed the ac stuff. I had a 67 440 c body that we pulled the brackets from in 2001 but they are the same as 68. One of my friends bought a 68 383 with ac new. He recalls the thermostat housing had the angle to it as well. We pulled this housing we have now from that same 67 440, but it has pinholes in the hose connection.
Re: 68 440 thermostat housing for AC [Re: fastmark] #2671099
06/28/19 12:00 PM
06/28/19 12:00 PM
moparx Offline
moparx  Offline
are those housings iron or aluminum ?
beer
Re: 68 440 thermostat housing for AC [Re: moparx] #2671127
06/28/19 01:14 PM
06/28/19 01:14 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
The one in my picture is steel. The one I just picked up from O’riellys is by Murray and the two halves of the casting do not line up good. I ordered another to see if it’s better. It’s aluminum.
Re: 68 440 thermostat housing for AC [Re: fastmark] #2671497
06/29/19 11:16 AM
06/29/19 11:16 AM
moparx Offline
moparx  Offline
thanks mark. aluminum is what i need. i'm not concerned about how the casting lines up, as i'm going to blend, or remove the lines, then blast to blend that area in.
could you please tell me the maker and part number, if possible ? TIA !
beer
Re: 68 440 thermostat housing for AC [Re: moparx] #2671839
06/30/19 09:47 AM
06/30/19 09:47 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
The two halves do not line up so it may leak if you don’t work the parting line some with a burr. Don’t know if you can see that in this picture. I ordered another to see if this is just one bad casting or the whole run is bad. The part no is a Murray 84805.
Re: 68 440 thermostat housing for AC [Re: fastmark] #2671842
06/30/19 09:56 AM
06/30/19 09:56 AM
moparx Offline
moparx  Offline
thanks for the part # !
i see what you mean on the sealing surface. thanks for pointing that out as well.
will be interesting to see how the other one you ordered compares.
beer
Re: 68 440 thermostat housing for AC [Re: moparx] #2671933
06/30/19 01:11 PM
06/30/19 01:11 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
The other one I ordered has the same flaw but not as bad. I’d try another brand and not the Murray.
Re: 68 440 thermostat housing for AC [Re: fastmark] #2672862
07/02/19 07:46 AM
07/02/19 07:46 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Re: 68 440 thermostat housing for AC [Re: mopars4ever] #2672871
07/02/19 07:59 AM
07/02/19 07:59 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Just what he wanted, another rusty, pitted used piece at inflated pricing.
Re: 68 440 thermostat housing for AC [Re: Sniper] #2672878
07/02/19 08:10 AM
07/02/19 08:10 AM
md
mopars4ever Offline
mopars4ever  Offline
md
I would use that piece anyday over some china junk. Overpriced at $24 please!
Re: 68 440 thermostat housing for AC [Re: Sniper] #2672910
07/02/19 09:32 AM
07/02/19 09:32 AM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I just paid $105 for a very nice nos one off eBay. It’s actually for my 65 Plymouth cop car with no AC.
Re: 68 440 thermostat housing for AC [Re: mopars4ever] #2673476
07/03/19 05:52 AM
07/03/19 05:52 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Wow. NOS. That is exactly what I have. I would have bought that if I would have seen it before I ordered the one I got. It’s just surface rust. Mine cost $22 and is made overseas. I think the one I bought will last ok. It is installed and fits. My customer just let it sit for 15 plus years after we restored the car with no maintenance and everything rusted and corroded up on the inside. Antifreeze does not last forever.
Re: 68 440 thermostat housing for AC [Re: fastmark] #2673517
07/03/19 09:40 AM
07/03/19 09:40 AM
NW Illinois
MoonshineMattK Offline
NW Illinois
Another option could be to sandblast the housing and fill the pits with JB weld. I've used it on many cars over the years with great success
