Re: eddy alum rpm heads with stock hp 440 manifolds [Re: Mr.Yuck] #267088
03/26/09 02:31 PM
03/26/09 02:31 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline OP
well if a guy on here made 570 hp on a low deck,with eddys and manifolds how much can you be losing 40hp over headers it wont be much. i want to retain the stock look, not a race car, show car. im sure it will run better than tired, heavy 906s
I'm guessing that is a heavily modified enigine. And the Main's were "hogged" out some. I don't think they up-grade on a stockish 440-6 would be the same. You'd probably add more HP by getting a set of headers.
It was a 470" engine , nothing real exotic in the build, flat tappet cam, the manifolds were AS CAST ...
so you think a pair of headers is going to gain as much as changing from a set of heads that flow maybe 220 at .500 to a pair of heads that flow 280 plus at .500 ???
I think there are easier and cheaper ways to get HP than bolting on a set of Eddy heads. Especially if you are going to choke them up w/ a set of exhaust Mani's. Why not run the stock 2.25 exhaust while you're at it?
ok lets go back to sqaure one the confines of the the build: 1970 v-code all oe 440+6 4spd 410 dana show car with only 2 mods on car. motor bay must look all stock from stock oil pan,stock 6bbl intake,stock manifolds,stock rad/fan anything between these parts is all fair game.. ie stroker kit,solid cam,alum heads ect..no headers,no aftermarket intakes. love to hear any combos on big blocks wedges with alum heads with manifolds
MOPAR OR NO CAR
Re: eddy alum rpm heads with stock hp 440 manifolds [Re: hemigod426] #267089
03/26/09 02:37 PM
03/26/09 02:37 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
"ok lets go back to sqaure one the confines of the the build: 1970 v-code all oe 440+6 4spd 410 dana show car with only 2 mods on car. motor bay must look all stock from stock oil pan,stock 6bbl intake,stock manifolds,stock rad/fan anything between these parts is all fair game.. ie stroker kit,solid cam,alum heads ect..no headers,no aftermarket intakes"
Then you can't use edy heads. They look nothing like the stock units. If you want the stock look the "stealth" heads are your only choice.
Re: eddy alum rpm heads with stock hp 440 manifolds [Re: hemigod426] #267090
03/26/09 04:05 PM
03/26/09 04:05 PM
AndyF Offline
AndyF  Offline
The six pack intake is probably the best factory intake to use for that type of build. Should be a fun combo.
The 500 rwhp is going to be tough to hit though. An easier target to hit would be 500 ft-lbs of torque. My low deck 470 with the AVS carb, RPM intake, Eddy heads and HP manifolds would lay down 530 ft-lbs of torque at 4300 rpm.
Re: eddy alum rpm heads with stock hp 440 manifolds [Re: AndyF] #267091
03/26/09 05:48 PM
03/26/09 05:48 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I wonder what HP ed cook is making , he is knocking on 10's with his 6pk , but I don't know what's been done to the intake , if anything , he is also using iron exh manifolds .
hemi , what class is allowing you to use alum heads ? is this a SHOW class , or racing ?
Re: eddy alum rpm heads with stock hp 440 manifolds [Re: JohnRR] #267092
03/26/09 06:51 PM
03/26/09 06:51 PM
Prospect, PA
BSB67 Online content
BSB67  Online Content
Prospect, PA
Going by memory, I think Ed's running about 125 mph at about 3900 to 4000lb in good air. You can figure hp from there. Moroso calls it about 590 net flywheel. The fact is that running nearly 10s @ 125 on manifolds is impressive to say the least. The 125 mph makes it clear that the exhaust manifolds can support a lot of power. I don't know if Ed's intake manifold is ported, but others have gone over 120 with unported intakes for sure.
Re: eddy alum rpm heads with stock hp 440 manifolds [Re: hemigod426] #267093
03/26/09 07:00 PM
03/26/09 07:00 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
