8 3/4 ring and pinion part numbers #2670070
06/26/19 07:48 AM
06/26/19 07:48 AM
Md.
J Brough Offline OP
J Brough  Offline OP
Md.
I have a ring and pinion that was removed from a 489 case. The ring gear number is 2070611 and the pinion number is 3507396. The date on the ring gear is 11 3 73, there is no date on the pinion. It is a 3.23 gear set I also have a gear set out of a 741 case. The ring gear from that case has the same 2070611 number on it. Do I have a set of gears that will work in a 489 case, or do I have a set of mismatched parts?
Thanks,
John
Re: 8 3/4 ring and pinion part numbers [Re: J Brough] #2670135
06/26/19 11:14 AM
06/26/19 11:14 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Does the ring have a hand written number that matches another hand written number on the pinion?
Re: 8 3/4 ring and pinion part numbers [Re: DoctorDiff] #2670367
06/26/19 07:36 PM
06/26/19 07:36 PM
Md.
J Brough Offline OP
J Brough  Offline OP
Md.
Yes. There is what looks to be a 0 with a line through it on both the ring and the pinion.
Re: 8 3/4 ring and pinion part numbers [Re: J Brough] #2670471
06/26/19 10:04 PM
06/26/19 10:04 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Sounds like you have a matched gear set.
Re: 8 3/4 ring and pinion part numbers [Re: DoctorDiff] #2670532
06/27/19 06:05 AM
06/27/19 06:05 AM
Md.
J Brough Offline OP
J Brough  Offline OP
Md.
Thanks Going to give them a try.
