Heat riser - ditch it or keep it?
#2669940
06/25/19 08:44 PM
06/25/19 08:44 PM
Posts: 2,059 NW/Indiana - Chi town
ricomondo
Having some 340 manifolds Jet Hot coated and do I really need to keep the heat riser assembly? It's not a concours car, so originality doesn't matter. If I ditch it, how do I get the flapper out? Cut grind it out with a dremel?
GY3 71 Demon 340
Re: Heat riser - ditch it or keep it?
[Re: ricomondo]
#2669952
06/25/19 09:14 PM
06/25/19 09:14 PM
Posts: 4,848 Memphis
HemiRick
Memphis
If you drive the car at all in cold weather you'll wish you kept it.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: ricomondo]
#2670068
06/26/19 07:31 AM
06/26/19 07:31 AM
Posts: 1,331 Clinton, NJ
njmopar
Clinton, NJ
I wanted to keep mine functional, although some parts were missing, so I had to order the rebuild kit anyway.
I got my manifolds jet hot coated, but sent in with the old bushings in place and I swapped them out with the ones in the kit after coating. I did make sure the old bushings were able to come out with no issues before sending in, to make it easier when the time came to drive them out. To get the old shaft off you either cut the shaft in two spots and remove the shaft in pieces or grind down the flapper where it is held on the shaft so you can slide out. Sliding out is a little more tricky as any burrs will get caught on the bushing as it comes out. More grinding or cleaning up is needed to get out.
To reinstall you need to tack weld the flapper back in place on the shaft, in the proper position. This is probably the most tricky part, clocking the shaft and flapper correctly. Lucky the welds are not visible, as my skills are not so great. As long as they hold, its fine. Take good photos before tearing apart, so you know what you are looking for.
[Re: ricomondo]
#2670092
06/26/19 09:10 AM
06/26/19 09:10 AM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
Had mine removed, but retained the stock look from the outside. The shop that did the coating removed it for me so I can't comment on exactly how to do it. Never gets cold enough here to worry about anything like that.
[Re: TJP]
#2670285
06/26/19 04:22 PM
06/26/19 04:22 PM
ricomondo
Well I don't foresee driving this car in cold weather ; say below 60, so I think I may see if I can get the butterfly out and keep the remaining parts in place just for looks. I read above where If I remove and replace with a repop heat rsier kit, I have to have some welding done? I'm not up for that as I've never done it. But thank you all for the replies.
GY3 71 Demon 340
[Re: an8sec70cuda]
#2670293
06/26/19 04:33 PM
06/26/19 04:33 PM
ricomondo
Had mine removed, but retained the stock look from the outside. The shop that did the coating removed it for me so I can't comment on exactly how to do it. Never gets cold enough here to worry about anything like that. Those look awesome!
GY3 71 Demon 340
[Re: FJR doc]
#2670461
06/26/19 09:46 PM
06/26/19 09:46 PM
ricomondo
I tossed mine when I redid my manifolds. I kept the counterweight installed for a factory look. I'm surprised how quiet the engine compartment is without the annoying heat riser rattle. That noisy riser drove me crazy every time I drove the car when I was younger. I even replaced the original with a NOS unit back in 1979. I ditched mine and I'm sure that I'll never miss it. Think my mind is made up, the flapper is gonna be taken out and the rest left in place. I'll see if I can have a neighbor possibly place a small tack on the counterweight so it's not spinning around an rattling.
GY3 71 Demon 340
