Re: BB roller cam lift question
[Re: lancer493]
#2672521
07/01/19 12:39 PM
07/01/19 12:39 PM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
There’s really only one way to know how much difference in power there would be.
The way I would look at it is........ how much extra power would the higher lift cam have to make....... for the swap to be worth the time and $$$ you’ll invest in it? And....... does that seem like a reasonable outcome for an increase in lobe lift of .020?
[Re: 451Mopar]
#2672588
07/01/19 03:10 PM
07/01/19 03:10 PM
Posts: 4,210 New York
polyspheric
New York
run the 1.5:1 rockers on the exhaust, and if you want more lift, put a 1.6:1 rocker on the intakes
This^^^, makes .660" = .704"
Boffin Emeritus
[Re: BradH]
#2673511
07/03/19 09:22 AM
07/03/19 09:22 AM
Posts: 289 St.Pete,Florida
lancer493
St.Pete,Florida
You're not really missing anything, Brad. This is a bucketlist project. Am 66yrs old. Am overbuilding, somewhat, looking for longevity thru durability.Valvetrain geometry correction kit coincidently, made the bigger 1.625" spring much easier to fit. I am building with the hopes that it stays together long enough for me to get it sorted out. 5.50's and the required 800-900hp needed to get there may sound much simpler on paper than it may really be. Megablock ,tool steel upper rings, aluminum rods,and ARP studs may be overkill, but chances are that the money Gods won't let me build another one.2.00" installed height made it easier to find a spring of that diameter at the pressures recommended for that lift. Not many choices with that height. I am actually at 1.95"- 1.97" installed height. As you know, valve stem length is the issue. Again, thanks for the guidance with the rocker stud issue. Turned out well and was not too difficult. Thanks, Bill
[Re: lancer493]
#2673870
07/04/19 01:45 AM
07/04/19 01:45 AM
Posts: 43,269 Bend,OR USA
Cab_Burge
Every 440 motor that I raced went faster with more air and fuel increase, bigger carb, bigger cam shaft and or bigger rocker ratio on the same cam went faster at the track, bigger heads that flowed more My first pump gas stroker motor had a decent solid roller cam in it, 260@.050 with .420 lobe lift on the intake lobes and 266 @.050 with .409 lobe lift ground on 108 LSA installed from 1.5 to 2.0 degrees advanced. I swap heads, rocker arms , intakes and carbs, all with the same camshaft and two different sets of lifters. First set of lifter had .750 diameter wheels(Mopar brand that broke two roller into two parts wheels before I replaced all of them ) and the second better set had .820 wheels, which made more duration and lift making the cam a little bigger That motor was a great experience and excellent learning for me, it started off running 10.69 at 124.MPH in my 3450 Lb. pump gas Duster with a set of ported big valve 906 iron heads with 9.25 to 1 compression ratio, I swapped the heads to a set of CNC ported Eddy RPM heads and that picked up the car to 10.49 at 127..MPH. I swapped the crank out from 4,250 stroke to 4.300 stroke crank to increase the compression from 9.25 to1 with the pistons down .025 up to zero deck height which increase the compression ratio to 10.29 to 1, that help it go quicker and faster also That was with a low deck six pack set up with original 440 automatic carbs. The final combination was with a set of Indy STR Max wedge intake ports and a Indy 400-3 intake with a 1050 CFM Holley Dominator carb. That help the car run 9.993 at 134.6 MPH through the muffs on Oregon pump swill with me in the car I had dyno tested a set of Indy CNC ported 440-1 heads also and they where worth right at 50 HP increase on the Duster pump gas motor over the SR heads on that motor on pump gas. I ended up using the 440-1 heads on a 440 stroker 526 C.I. race motor. that I ended up selling before racing it
[Re: lancer493]
#2674064
07/04/19 02:46 PM
07/04/19 02:46 PM
fast68plymouth
So. Burlington, Vt.
My experience is........ there’s usually a pretty big spread in $$$ and effort to get from 800 to 900. That being said, you made your decisions, bought your parts, and are putting it all together. It’ll make what it makes........ regardless of what anyone says about it.
