Page 2 of 3 1 2 3
Re: Did I just break a sprag? [Re: MR_P_BODY] #2669035
06/23/19 02:19 PM
06/23/19 02:19 PM
W. Pa
U
usp4u Offline OP
usp4u  Offline OP
U
W. Pa
Originally Posted by MR_P_BODY
How many rpms were you running at the time you hit it... MOST times
when a sprag gives out is when you get off the pedal then hit it again..
I blew a rear end in the race car but it didnt hurt the sprag.. I pulled the
trans for a check but it was fine.. the getting back on it after letting off
is what can hurt it... its that slap of the rollers that can break the roller
case.. in a manual VB its hard to tell if you cracked it.. pull it now while
you have the time... good luck
wave
Probably around 4000rpm
Re: Did I just break a sprag? [Re: usp4u] #2669045
06/23/19 02:52 PM
06/23/19 02:52 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Originally Posted by usp4u
just dropped the pan. zero trash.
the car will move in all gears........until you touch the throttle. then ZZZIIIIIIIIIIZZZZ from under the tunnel.
I did find two bolts convertor that were backing off. but that cant be it
and yes, "fmvb" = turbo-action forward manual valve body (forward to allow my slap-stik to work, no LBA) been in for about 10 years and 8k miles.
Do you have reverse?
Re: Did I just break a sprag? [Re: Sammy] #2669049
06/23/19 02:57 PM
06/23/19 02:57 PM
W. Pa
U
usp4u Offline OP
usp4u  Offline OP
U
W. Pa
Car moves in reverse and all other gears...until under a load. Then it sounds like splines "slipping/grinding" and does not want to move.
Re: Did I just break a sprag? [Re: usp4u] #2669052
06/23/19 03:13 PM
06/23/19 03:13 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
High gear drum is cracked or the front planetary is just about gone.
Highly doubt the sprag is broken.
Re: Did I just break a sprag? [Re: Sammy] #2669056
06/23/19 03:21 PM
06/23/19 03:21 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Not sure I understand 87 miles with no issues but it won't move and makes grinding noises under load. Regardless, it sounds like something is broken. It needs to go on the bench.
Re: Did I just break a sprag? [Re: CMcAllister] #2669076
06/23/19 04:39 PM
06/23/19 04:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Could be as simple as the low adjuster came loose and backing off.. drop
the pan and look.. you would end up draining it anyways if you have
to pull the trans
wave
Re: Did I just break a sprag? [Re: usp4u] #2669077
06/23/19 04:43 PM
06/23/19 04:43 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
It's possible that when you "poked it again" it was just shifting to 2nd and that stripped the splines in the front planetary. Only the postmortem will tell.
Re: Did I just break a sprag? [Re: John_Kunkel] #2669078
06/23/19 04:48 PM
06/23/19 04:48 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Transmission has to come out regardless
Re: Did I just break a sprag? [Re: usp4u] #2669128
06/23/19 08:08 PM
06/23/19 08:08 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Never broken one before.....full weight e body with drag radials, 402 small block, 727, turbo action fmvb, 3.91
Pulled out on street, poked it...car went sideways, I lifted, and poked it again.
ZIIIIIZZZZZZZZZZ
car moves under own power but any throttle produces more ZIIIIIIZZZZZZZZ.
not what I needed on a car I planned to drive to Carlisle in two weeks
down
I would say yes, it's done and is a bomb waiting to happen.
Re: Did I just break a sprag? [Re: camastomcat] #2669594
06/24/19 10:56 PM
06/24/19 10:56 PM
W. Pa
U
usp4u Offline OP
usp4u  Offline OP
U
W. Pa
Update in op
Re: Did I just break a sprag? [Re: usp4u] #2669776
06/25/19 12:44 PM
06/25/19 12:44 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Stripped all the teeth on a ring or pinion? Color me skeptical; if it's rear end related, more likely it's differential pinion gears.
Re: Did I just break a sprag? [Re: John_Kunkel] #2669791
06/25/19 01:35 PM
06/25/19 01:35 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
When I broke my 8 3/4 it didn't make a ZIIIIIIZZZZZZZZ noise. It was more bang, clunk, grind and pop. If the rear gear is broke it'll be easy enough to tell when rolling the tires with the driveshaft out.
Re: Did I just break a sprag? [Re: John_Kunkel] #2669825
06/25/19 03:33 PM
06/25/19 03:33 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Me too. Could be a stripped spline in the yoke or maybe an axle spline gave up.
Too bad you didn't have someone look under the car before you pulled the trans. If you loaded it against the brakes and the drive shaft turned but the wheels didn't, you might have saved some labor.
Kevin
Re: Did I just break a sprag? [Re: Twostick] #2669843
06/25/19 04:50 PM
06/25/19 04:50 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Stripped splines usually either work, or they don't. I've never seen one that held at low power, then partially slipped at full throttle (making the ZZZZZZZZZ noise), and then go back to working at low power again. But there is a first for everything I guess!
If it's making noise in all gears, then it's probably not a planet, because the planets don't get used in high gear (at least not that the planetary gear themselves has movement.) It's all locked together to get the 1:1 under that scenario.
Does the ZZZZZZZZZZZ noise match engine RPM, or road speed RPM? That would help diagnose what part might be hurt.
And just to clarify... it makes the ZZZZZZZZZ noise in 1st, 2nd, 3rd, and Reverse under throttle? When it makes this ZZZZZZZZZZ noise, does the car barely move, or does it still seem to be putting most of the power to the ground?
Re: Did I just break a sprag? [Re: dizuster] #2669957
06/25/19 09:17 PM
06/25/19 09:17 PM
W. Pa
U
usp4u Offline OP
usp4u  Offline OP
U
W. Pa
Pulled rear apart...
Right axle splines stripped off.
Re: Did I just break a sprag? [Re: usp4u] #2670044
06/26/19 06:11 AM
06/26/19 06:11 AM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
That will do it!!!!
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: Did I just break a sprag? [Re: usp4u] #2670093
06/26/19 09:14 AM
06/26/19 09:14 AM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
You should now check the sprag to be on the safe side. twocents
72 Plymouth Roadrunner 11.08@123.25
Re: Did I just break a sprag? [Re: Roughbird72] #2670123
06/26/19 10:33 AM
06/26/19 10:33 AM
W. Pa
U
usp4u Offline OP
usp4u  Offline OP
U
W. Pa
That's the plan
Re: Did I just break a sprag? [Re: usp4u] #2670203
06/26/19 01:33 PM
06/26/19 01:33 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Just the outer tip or all across? Got a pic?
Re: Did I just break a sprag? [Re: John_Kunkel] #2671421
06/29/19 08:18 AM
06/29/19 08:18 AM
maryland
mhead Offline
mhead  Offline
maryland
My 904 just broke the sprag last Saturday at the starting line.I always start my burnout in 2nd then 3rd so not sure why it broke.Car would move in all gears but when I started to get on it in 1st was like I put the car in neutral.I couldn't hear any grinding because of open headers.Better check your sprag.
Page 2 of 3 1 2 3
